Hello Guest it is October 16, 2026, 05:43:42 AM
Author Topic: Mach ignores M00, loads macro; 'terminating scripts'  (Read 20985 times)
Re: Mach ignores M00, loads macro; 'terminating scripts'
« Reply #10 on: April 30, 2015, 01:57:06 PM »
works fine here, .lic or not.
Only difference is ver and the port driver is loaded here.
Maybe load the driver ? ? and try it ? ?
Stranger things have happened.
« Reply #11 on: April 30, 2015, 01:59:51 PM »
There's a setting in General Config to ignore M codes when loading g-code. That may be your issue.
« Reply #12 on: April 30, 2015, 02:08:53 PM »
Thanks ger, found that; should I tick it's box then??
« Reply #13 on: April 30, 2015, 02:11:16 PM »
Gerry is faster typing than me. Yep tick the box ignore mcodes on load.
« Reply #14 on: April 30, 2015, 02:18:32 PM »
Trying it with the box ticked, and using the 6 macros I was testing earlier today. Its really slow, but looks like its okay so far. Maybe that was the problem? I think it's now decrementing an axis waiting for a non existant switch to tell it it's hit the end of its travel, so I'd say it pretty much works now.
Just one box unticked, that seems to have been it.
Thanks again all!
