Hello Guest it is October 16, 2026, 05:04:29 PM
Author Topic: Save Work Offsets  (Read 10122 times)
Offline Greolt
  •  956 956
Save Work Offsets
« on: April 21, 2007, 09:30:53 PM »
I have a fixture setup at a known position on my table.
Set "Fixture 2 (G55)" to the coordinates matching that fixture in the Save Work Offset table.
Home machine then select G55 offset, "Goto Z" puts me right where I want to be.  All good so far.
If for any reason I zero an axis it changes the G55 offset in the "Save Work Offset" table.
I don't want this to happen. I then have to re enter and save the correct offset in the table again.
Which check box on the General Config Page must I set to not allow the offset to change until I want it to?
Thanks,  Greg
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Save Work Offsets
« Reply #1 on: April 22, 2007, 03:40:02 AM »
You could set up an M code macro with a G10 in it that sets your offsets for you, that way they will never get lost and also you can enter the M code in all the programs that use that fixture offset.
E.g.
G10 L2 P2 Xnnn.nnn Ynnn.nnn Znnn.nnn
Graham.
Offline Greolt
  •  956 956
« Reply #2 on: April 24, 2007, 05:51:00 PM »
Thanks for that Graham. I may need to do that.
Just seems a bit strange to have a "Save Work Offsets" button that leads to a table to enter offsets and select save.
Then have these altered by other operations and catch you out when you don't want them to be.
Was hoping I just needed to have the correct selections made in General Config to not allow these unwanted changes to happen.
Greg
