Hello Guest it is October 24, 2026, 05:14:12 PM
Author Topic: csmio/ip-a communication problem  (Read 19584 times)
« on: April 27, 2015, 05:24:32 PM »
I have  a csmio/ip-a  i can not get it to communicate . I run firmware uploader it says " no device found " .when i click on plug in comtrol  in mach3 it says "csmio not connected. i have it connected direct to the computer with the crossover cable. there is nothing connected to the csmio except cable and the power. i turned the power on then waited to connect the cable , but i get the same thing.I have spent more time then i want  trying to get this to work .the computer is not connected to the net , but i brought it in from the shop to download thefirmware and Microsoft NetFramework 3.5  . ithis thing is about to end up in a corner .
Offline TPS
  •  2,627 2,627
Re: csmio/ip-a communication problem
« Reply #1 on: April 28, 2015, 12:39:23 AM »
have you set the ip-adress of your PC ?
csmio has notmaly 10.1.1.2.
is your PC in the same network (depending on IP adress)?
can you oing 10.1.1.2 ?
« Reply #2 on: April 28, 2015, 05:25:31 AM »
Im not very cuputer savvy , but i did set the ip  address to 10.1.1.1 and the mask to 255.255.255.0 as the manual says.as far as pinging im not sure how to do that.what do you mean "is your pc in the network"
Offline TPS
  •  2,627 2,627
« Reply #3 on: April 28, 2015, 05:43:09 AM »
got start -> run  enter cmd
cmd box showes up
in this cmd box type:  ping 10.1.1.2 + Enter
then you should see that the csmio is reachable or not.
« Reply #4 on: April 28, 2015, 06:25:51 AM »
i dont understand what you are saying"got start -> run  enter cmd
cmd box showes up". also why are you saying 10.1.1.2 for the ip ,in the manual it says to enter 10.1.1.1
« Reply #5 on: April 28, 2015, 07:19:23 AM »
Okay I did the ping test . ip 10.1.1.1  4 sent  0 received  4 lost
                                    ip  10.1.1.2  4 sent  4 recives 0 lost
this just tells me what i already know, there no cumunication
Offline TPS
  •  2,627 2,627
« Reply #6 on: April 28, 2015, 08:07:00 AM »
ok not realy.
your PC is set to 10.1.1.1
CSMIO is set by default to 10.1.1.2
and the ping for 10.1.1.2 says 0 lost, what means your pc can "reach" it.
can you open a cmdbox again and try a IPCONFIG + enter ?
are you sure that you have installed CSMIO software for the IP/A?
http://www.cs-lab.eu/de/upload/firmware/setup_CSMIO-IP-A-2.603.zip
« Reply #7 on: April 28, 2015, 03:19:40 PM »
I did ipconfig , says " media disconnected "
Offline TPS
  •  2,627 2,627
« Reply #8 on: April 29, 2015, 01:54:03 AM »
there are two led's at the network connector on the csmio/a.
what is their status ?
« Reply #9 on: April 29, 2015, 05:27:51 AM »
I have seen them flashing when i turned the power on. I just got off work ,later I think I will connect the computer to the net and down load the software. maybe there is a problem with the disk.
