Hello Guest it is November 23, 2026, 04:31:57 AM
Author Topic: Wacky towards the end of G code  (Read 25541 times)
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: Wacky towards the end of G code
« Reply #10 on: April 22, 2015, 10:38:43 AM »
Just a shot in the dark but if you scroll right to the bottom of your code in the code window, do you see the M30?
« Reply #11 on: April 22, 2015, 10:50:43 AM »
Are you certain that you replaced the old license correctly ? In the proper place ?
Click HELP/About to check.
(I noticed that the M30 did not paste into the copy as well Ian ... nice catch)
« Reply #12 on: April 22, 2015, 10:56:06 AM »
Is this an LPT version or do you use an outside controller ??
Any more that needs to be the first question asked (;-)
« Reply #13 on: April 22, 2015, 10:59:52 AM »
Yes M30 is there:
Y0.292Z-3.595
Y0.286Z-3.595
Y0.000Z-3.625
G0Z5.000
G0X0.000
G0Z5.000
G0X0Y0
M30
When I start Mach3 title bar says Licensed to: My name.
TB6560 is connected to LPT.
Offline stirling
  •  2,188 2,188
  • UK
« Reply #14 on: April 22, 2015, 12:12:24 PM »
Just to be clear, I know M30 is the last line of your code but I asked if it's visible as the last line in the code window.
« Reply #15 on: April 22, 2015, 12:46:14 PM »
Yes. It is visible in the code window.
« Reply #16 on: April 22, 2015, 01:27:43 PM »
I tried turning off toolpath as Tweakie suggested in his first post and it seams that did the trick. I'm machining new piece with 360,000 lines of code; once done I will confirm if toolpath display indeed solve the issue.
« Reply #17 on: April 22, 2015, 05:46:03 PM »
Just to confirm. Turning the toolpath display off fixed the problem.
Thank You guys.
