Hello Guest it is November 23, 2026, 04:31:59 AM
Author Topic: Wacky towards the end of G code  (Read 25542 times)
« on: April 19, 2015, 09:49:15 AM »
Hello All;
Hopefully someone can shed some light on my problem.
I run relief cut from Artcam. It takes from 3-8 hours to finish and towards the very end, when only few lines left to finish machine gets stuck. I tried changing orientation of a cut but didn't help.
Any help would be greatly appreciated.
  •  9,378 9,378
Re: Wacky towards the end of G code
« Reply #1 on: April 19, 2015, 10:34:12 AM »
Just a shot in the dark but it could be that your graphics card is struggling (as can happen with long Gcode programs). Try running your Gcode program with the ToolPath switched off (Diagnostics screen) and see if that cures the problem. If it does then perhaps upgrade your graphics card (more ram).
« Reply #2 on: April 19, 2015, 11:26:15 AM »
Thanks, will try that.
Just to be clear, it is not the PC that gets stuck, rather the table loses position and moves to some odd place.
  •  9,378 9,378
« Reply #3 on: April 19, 2015, 11:34:03 AM »
Ahh - that's a different problem - I thought it was the PC that stopped.
Before going further could you please check with Licensing http://www.machsupport.com/contact-us/ to verify that you are using a genuine Mach3 license.
« Reply #4 on: April 19, 2015, 11:37:00 AM »
Sure. How do I do that?
  •  9,378 9,378
« Reply #5 on: April 19, 2015, 12:05:37 PM »
 I have sent you a PM to explain.
« Reply #6 on: April 22, 2015, 06:40:52 AM »
Go figure, machine came with the pirated license. I bought new license today under my name.
I'll let you know if this solved the issue on hand.
« Reply #7 on: April 22, 2015, 08:46:28 AM »
Purchasing new license didn't fix the issue.
Still, after 350,000+ lines of code, on the last few lines machine goes crazy.
« Reply #8 on: April 22, 2015, 08:59:22 AM »
Can you post the last portion of the code ?
Does other code run OK ?
Does it occur at a G0 move ?
Excessive heat at the drives ? motors ? (would be strangely coincidental)
« Reply #9 on: April 22, 2015, 10:02:37 AM »
It happens every time I run longer code. It doesn't matter if the code is 300,000 lines or 500,000 lines. It always happens on the very few last lines (less then a millimeter of final carving work).  Mach runs through the rest of the code, and goes on the first line as everything was done, but the machine will go left-right few centimeters forever. Sometimes it even gets stuck. But always losses XY position after this (Z is fine).
Here is the bottom part of the code:
Y285.562Z-3.050
Y285.714Z-3.185
X1.700Z-3.188
Y285.497Z-3.013
Y285.103Z-2.805
Y284.743Z-2.687
Y284.370Z-2.618
Y283.793Z-2.582
Y2.187Z-2.582
Y1.800Z-2.602
Y1.419Z-2.655
Y1.050Z-2.747
Y0.700Z-2.884
Y0.371Z-3.076
Y0.000Z-3.381
X1.500Z-3.382
Y0.436Z-3.037
Y0.724Z-2.886
Y1.246Z-2.701
Y1.609Z-2.640
Y2.379Z-2.610
Y284.050Z-2.617
Y284.436Z-2.653
Y284.815Z-2.730
Y285.180Z-2.856
Y285.525Z-3.038
Y285.714Z-3.188
X1.300Z-3.199
Y285.446Z-3.008
Y285.120Z-2.851
Y284.764Z-2.742
Y284.393Z-2.681
Y283.818Z-2.653
Y2.001Z-2.656
Y1.673Z-2.670
Y1.287Z-2.720
Y0.907Z-2.825
Y0.542Z-2.993
Y0.195Z-3.228
Y0.000Z-3.393
X1.100Y-0.000Z-3.412
Y0.218Z-3.231
Y0.436Z-3.082
Y0.666Z-2.970
Y1.033Z-2.833
Y1.412Z-2.755
Y2.178Z-2.708
Y283.985Z-2.711
Y284.315Z-2.726
Y284.701Z-2.777
Y285.078Z-2.876
Y285.440Z-3.032
Y285.714Z-3.216
X0.900Z-3.254
Y285.497Z-3.117
Y285.279Z-3.013
Y284.912Z-2.881
Y284.339Z-2.794
Y281.300Z-2.779
Y1.995Z-2.782
Y1.489Z-2.811
Y1.103Z-2.872
Y0.719Z-3.001
Y0.348Z-3.202
Y0.000Z-3.451
X0.700Z-3.503
Y0.218Z-3.318
Y0.602Z-3.105
Y0.957Z-2.985
Y1.327Z-2.913
Y1.902Z-2.877
Y284.002Z-2.875
Y284.342Z-2.887
Y284.726Z-2.933
Y285.099Z-3.020
Y285.455Z-3.154
Y285.714Z-3.301
X0.500Z-3.386
Y285.279Z-3.164
Y284.916Z-3.053
Y284.538Z-3.001
Y282.305Z-2.984
Y1.728Z-2.988
Y1.396Z-3.003
Y1.011Z-3.061
Y0.636Z-3.181
Y0.281Z-3.364
Y0.000Z-3.550
X0.300Y-0.000Z-3.615
Y0.086Z-3.583
Y0.436Z-3.384
Y0.800Z-3.248
Y1.371Z-3.146
Y2.891Z-3.127
Y284.236Z-3.129
Y284.566Z-3.143
Y284.951Z-3.197
Y285.324Z-3.301
Y285.714Z-3.479
X0.141Z-3.594
X0.138Z-3.596
X0.100Z-3.601
Y285.677Z-3.601
Y285.674Z-3.600
Y285.279Z-3.423
Y284.923Z-3.337
Y284.548Z-3.297
Y1.384Z-3.300
Y1.000Z-3.347
Y0.631Z-3.446
Y0.292Z-3.595
Y0.286Z-3.595
Y0.000Z-3.625
G0Z5.000
G0X0.000
G0Z5.000
G0X0Y0
M30
