Hello
Guest
it is
November 23, 2026, 04:32:04 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Wacky towards the end of G code
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Wacky towards the end of G code (Read 25545 times)
stirling
2,188
UK
Re: Wacky towards the end of G code
Reply #10 on:
April 22, 2015, 10:38:43 AM »
Just a shot in the dark but if you scroll right to the bottom of your code in the code window, do you see the M30?
Logged
Razordance Torch Height Control
Overloaded
4,923
Reply #11 on:
April 22, 2015, 10:50:43 AM »
Are you certain that you replaced the old license correctly ? In the proper place ?
Click HELP/About to check.
(I noticed that the M30 did not paste into the copy as well Ian ... nice catch)
Logged
BR549
6,965
Reply #12 on:
April 22, 2015, 10:56:06 AM »
Is this an LPT version or do you use an outside controller ??
Any more that needs to be the first question asked (;-)
Logged
sskoko
10
Reply #13 on:
April 22, 2015, 10:59:52 AM »
Yes M30 is there:
Y0.292Z-3.595
Y0.286Z-3.595
Y0.000Z-3.625
G0Z5.000
G0X0.000
G0Z5.000
G0X0Y0
M30
When I start Mach3 title bar says Licensed to: My name.
TB6560 is connected to LPT.
Logged
stirling
2,188
UK
Reply #14 on:
April 22, 2015, 12:12:24 PM »
Just to be clear, I know M30 is the last line of your code but I asked if it's visible as the last line in the code window.
Logged
sskoko
10
Reply #15 on:
April 22, 2015, 12:46:14 PM »
Yes. It is visible in the code window.
Logged
sskoko
10
Reply #16 on:
April 22, 2015, 01:27:43 PM »
I tried turning off toolpath as Tweakie suggested in his first post and it seams that did the trick. I'm machining new piece with 360,000 lines of code; once done I will confirm if toolpath display indeed solve the issue.
Logged
sskoko
10
Reply #17 on:
April 22, 2015, 05:46:03 PM »
Just to confirm. Turning the toolpath display off fixed the problem.
Thank You guys.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
