Hello Guest it is November 23, 2026, 04:49:30 AM
Author Topic: Mach3 issues on Windows Xp! Please help!  (Read 35785 times)
Re: Mach3 issues on Windows Xp! Please help!
« Reply #10 on: April 20, 2015, 09:14:49 AM »
Not sure if Windows 2000 will work. Windows 2000 is one step up from Windows 98 and may not work with Mach 3 plug-ins and stepper drivers. I know Win98 and 2000 have USB limitations as well.
Most if not all pirate (unlicensed) XP OS use a "crack utility" to unlock the OS so it's a good possibility not all of the OS is being loaded properly. Especially if it's happening on two separate pc's and the only common denominator is the same OS being loaded on both. Ebay has tons of cheap XP computers and XP OS disks with a license.
« Last Edit: April 20, 2015, 09:17:04 AM by geh7552 »
« Reply #11 on: April 20, 2015, 09:20:14 AM »
So you say do not to change to 2000, just to stay with Xp but with licensed version? Like that I have understood..
« Reply #12 on: April 20, 2015, 10:04:01 AM »
W2K will work fine with Mach3. It is NOT  even close to W98. USB works fine as well. The only difference in W2K is you have to manually disconnect the USB before removing it from the system.
« Reply #13 on: April 20, 2015, 10:07:24 PM »
Really I didn't know what to do! Or to install windows 2000 or to stay on Xp! I didn't know!
My problem is that I have finished my machine and now I need to move it! But I'm conern to make for me problem on the future!
« Reply #14 on: April 21, 2015, 08:57:25 AM »
Try 2000 and see if it works if you have a licensed copy. If its a bogus copy like the XP you have it may end up with the same results. IMO It's really a no brainer to go with licensed copy of XP instead of 2000 OS. There are a number of OS improvements over 2000. XP is readily available on Ebay for low cost. Do a clean install and move on.... it's not rocket science.
« Reply #15 on: April 21, 2015, 09:04:30 AM »
Its not a rocket science! I like it man ;)
« Reply #16 on: April 21, 2015, 11:34:25 PM »
Ok guys thanks you so much for your help, but what about the charge pump? There are no body have asked me anout it!
Are the SCHP help me here? Or have some correlation here?
« Reply #17 on: April 22, 2015, 10:42:43 AM »
I would also suggest getting all the updates installed in either operating system, before you load Mach.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #18 on: April 22, 2015, 12:30:39 PM »
So you've switched to a licensed copy of windoze yet? C'mon dude you can't be running hooky software and then complain it doesn't work. You get what you pay for right?
« Reply #19 on: April 22, 2015, 03:33:35 PM »
Bar553, did you mean the updates of Windows?
Stirling, excuse me man but I didn't understood you! But I didn't switched yet to a licensed version, now I thinking about the SCHP! What you think man?
