Hello Guest it is November 22, 2026, 07:42:08 AM
Author Topic: Z axis Home?  (Read 8984 times)
Z axis Home?
« on: April 04, 2015, 03:08:23 PM »
I have my new CNC router up and running, it's a PDJ 2626 running Mach3.
I have ref home on X and Y working just as they should, but Z is another story. If I turn on Z Home in Port & Pins Inputs when I click on Ref All Home the Z axis goes down instead of up. If I reverse the motor then it zeros to the top but in operation the Z axis moves in the wrong direction. I've tried every setting I can think of I'm just missing something and need help....
Here are my configuration settings.
Re: Z axis Home?
« Reply #1 on: April 08, 2015, 06:09:53 PM »
Take the tick out of Home Negative for the Z axis, see pic. You want the Z to home in a positive direction, ie up the way.
Re: Z axis Home?
« Reply #2 on: April 08, 2015, 06:17:08 PM »
Hood, You da Man!!!
Works great!!!
