Hello Guest it is November 12, 2026, 09:43:43 PM
Author Topic: 5 axis kinematics coming soon !!!  (Read 119953 times)
Re: 5 axis kinematics coming soon !!!
« Reply #20 on: April 04, 2015, 01:46:37 PM »
i know a lot of people think it's not possible to have 5 axis kinematics with mach3, but wait the demo version and you could judge it ( two month an half of working to create the plugin)
thanks
« Reply #21 on: April 09, 2015, 12:22:15 AM »
Sorry for the delay, the plugin will be available tomorrow.
Some changes since, you will have now the possibility to test the editor but with a limited lines numbers.
Offline dude1
  •  1,253 1,253
« Reply #22 on: April 09, 2015, 12:56:43 AM »
dude that really cool you just need to do it for M4 now
« Reply #23 on: April 09, 2015, 10:46:52 AM »
KRW, I did check and it IS theoretically possible to do it . But doing kinematics in Mach3 really ONLY has an advantage when working with rotary jointed arms such as robotic arms.  The only advantage it serves that I can see in normal CNC work is you can world point jog.
Normally the CAM does all the kinematics calculations and applies it to the Gcode output. SO to do most 5axis work you will still have to Cam it.
Waiting to see the demo, (;-) TP
« Reply #24 on: April 10, 2015, 02:35:29 AM »
Hi BR549,
Thanks for your interest but i'm sorry to say you that, but i think you dit not understand the aim of my plugin. I wrote this plugin to use kinematics moves to help us to position tools in differents plans with goods coordinates for precision milling like a real 5 axis milling machines without cad-cam software using (positionned milling,  not continuous milling). Not just for simple kinematics moves. A video will watch a real use of the plugin in the end of tutorial.
Best regards
« Reply #25 on: April 10, 2015, 09:04:31 AM »
You are correct(;-) I have no idea what you are planning. Without seeing the mach3 screen when the machine is in motion to see what code you are running it all looks the same from here.
« Reply #26 on: April 14, 2015, 05:18:40 AM »
the tutorial is online http://mach3fiveaxis.top-eb.fr/
the download will be available this night.
thanks
  •  9,377 9,377
« Reply #27 on: April 14, 2015, 07:01:28 AM »
Excellent tutorial and video's Krw125, my congratulations on your work.
« Reply #28 on: April 14, 2015, 09:23:11 PM »
The download is now available
top-eb.fr/mach3fiveaxis
Have fun  :)
« Reply #29 on: April 14, 2015, 09:36:33 PM »
Tweakie can you translate to me what he is doing ? I don't read French.
(;-)TP
