Hello Guest it is October 24, 2026, 07:09:14 PM
Author Topic: CSMIO/IP diagnostic window  (Read 11793 times)
« on: March 31, 2015, 04:33:44 PM »
on the CSMIO/IP diagnostic window at the supply voltage -24 it says 119.85v in the display.
have check the supply voltage with a meter and getting just over 24 volts. anybody have any ideas why?
the 5 volt is fine and the cpu temp is at 37C which seems a little warm but really don't know
Re: CSMIO/IP diagnostic window
« Reply #1 on: April 07, 2015, 12:55:00 PM »
I have no idea why the voltage would display as such, mine display correctly on the two machines I have the CSMIO on.
Are you using an up to date plugin/firmware?
« Reply #2 on: April 07, 2015, 04:11:30 PM »
some thing must of happened with ip/a . had emailed cs lab about it and the said, send the  controller back.
they are sending a new one out.
« Reply #3 on: April 08, 2015, 03:39:41 AM »
Ok, hopefully they will sort you out quickly :)
