Hello Guest it is November 01, 2026, 10:06:04 AM
Author Topic: Lazy Cam (Beta)  (Read 59008 times)
ynneb
Lazy Cam (Beta)
« on: March 04, 2006, 08:38:27 PM »
As many of you may be aware, the Beta of lazy Cam has been released.
You can download it from here http://www.machsupport.com/LazyCam.zip
Let us know your thoughts / problems / praises.
This section should provide a good collective feedback for all your input.
« Last Edit: March 05, 2006, 03:34:55 AM by ynneb »
Re: Lazy Cam (Beta)
« Reply #1 on: March 05, 2006, 07:05:13 AM »
Please post any files that are giving you trouble and please explane how you are getting the problem ...  This first release is to see how you like the workflow. I will fix any bugs that I can as well  ;D
Have fun breaking it  :o
www.newfangledsolutions.com
www.machsupport.com
Re: Lazy Cam (Beta)
« Reply #2 on: March 06, 2006, 06:46:55 PM »
There never was a problem other than the problem that people dont have mach3 installed:) maybe the licence is needed too.
Jon
Re: Lazy Cam (Beta)
« Reply #3 on: March 07, 2006, 09:47:02 PM »
LazyCam 1.01 Update here: http://www.machsupport.com/LazyCam.zip
There are a few very small updates:
1. The move button will update all of the Leadin properties now
2. The Rapid Height in the layer dialog wouldn't take a none integer value... (No so good if you cut in inch)
I am working on the Dot Width Diffusion, Drilling code (Points), and there is a small bug putting on a leadin on some chains...
All and all it seems to be going well, I can see that the base code that Art and I worked on is going to be very robust!
Thank you to everyone that is helping with the testing
Brian
www.machsupport.com
