Hello Guest it is November 13, 2026, 09:43:16 AM
Author Topic: Mach3 Lathe - Can't Cut Straight 45 degree Angles  (Read 9398 times)
« on: March 16, 2015, 03:11:40 PM »
All,
I've upgraded my DM-300 lathe to mach 3. There are irregularities when cutting 45 degree angles (see attached pic). I thought the problem was hardware, but thought it maybe mach3 when looking at the cut preview window (see neon highlighted area in pic). The cut part looks EXACTLY like this. I tightened everything on the machine just to make sure and it is still occurring.
Anyone ever run into something like this before?
Software version is 3.043.066.
Thanks Guys!
Re: Mach3 Lathe - Can't Cut Straight 45 degree Angles
« Reply #1 on: March 16, 2015, 04:11:53 PM »
I would suggest you do not use 066, for a lathe in particular, it has issues with tool wear offsets amongst other things, that however is not your problem here.
The toolpath view is just a representation and thus will show irregularities.
 It is most likely a mechanical issue, assuming the code is fine.
 It may also be a resolution issue if your steps per unit are unusually course.
