Hello
Guest
it is
November 13, 2026, 01:46:41 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Deos Mach3 send pulses to controller?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Deos Mach3 send pulses to controller? (Read 13985 times)
artman12us
13
on:
March 14, 2015, 09:46:52 PM »
Does the driver in mach3 send clock signal to my controller board? If so what pin on the parallel is it sending it to. Thanks Art
Carnoustie, Scotland
Re: Deos Mach3 send pulses to controller?
Reply #1 on:
March 15, 2015, 02:58:19 AM »
It sends them to whichever pin you have set in Ports and Pins, Motor Outputs, for each axes step pin.
artman12us
13
Reply #2 on:
March 15, 2015, 06:30:31 AM »
BR549
6,965
Reply #3 on:
March 15, 2015, 12:32:19 PM »
That would depend on What you mean by controller.
artman12us
13
Reply #4 on:
March 15, 2015, 05:05:00 PM »
I will explain. I had a Hobby CNC 4 axis board that went Kaput. They no longer sell a 4 axis board so I bought 2 - 3 axis boards. I put one together and it works fine with all three axis. So I put the second board together with only the x axis driver chip in to act as the A axis and jumpered pin 2 and 3 of this board to pins 8 and 9 on the first boards serial port. but the fourth axis motor has power but it is not moving. So I wondered if there was another signal I had to get from the second board to the parallel port which is suppose to act as the A axis. Thanks Art
Reply #5 on:
March 16, 2015, 09:50:21 AM »
Could it be your second board needs an external power source?
artman12us
13
Reply #6 on:
March 16, 2015, 10:19:36 AM »
No I have power to the motors. I thought maybe I needed to connect a enable pin so I connected pin 1 on one board to pin 1 on the other (parallel port) but that didn't work. This is why I was trying to understand every pin that mach uses on the parallel port. Thanks for your help especially because its more of a electronic problem and not mach per se. Art
Print
Pages:
1
Go Up
« previous
next »
