Hello Guest it is November 13, 2026, 12:16:19 PM
Author Topic: Deos Mach3 send pulses to controller?  (Read 13978 times)
« on: March 14, 2015, 09:46:52 PM »
Does the driver in mach3 send clock signal to my controller board? If so what pin on the parallel is it sending it to. Thanks Art
Re: Deos Mach3 send pulses to controller?
« Reply #1 on: March 15, 2015, 02:58:19 AM »
It sends them to whichever pin you have set in Ports and Pins, Motor Outputs, for each axes step pin.
« Reply #2 on: March 15, 2015, 06:30:31 AM »
« Reply #3 on: March 15, 2015, 12:32:19 PM »
That would depend on What you mean by controller.
« Reply #4 on: March 15, 2015, 05:05:00 PM »
I will explain. I had a Hobby CNC 4 axis board that went Kaput. They no longer sell a 4 axis board so I bought 2 - 3 axis boards. I put one together and it works fine with all three axis. So I put the second board together with only the x axis driver chip in to act as the A axis and jumpered pin 2 and 3 of this board to pins 8 and 9 on the first boards serial port. but the fourth axis motor has power but it is not moving. So I wondered if there was another signal I had to get from the second board to the parallel port which is suppose to act as the A axis. Thanks Art
« Reply #5 on: March 16, 2015, 09:50:21 AM »
Could it be  your second board needs an external power source?
« Reply #6 on: March 16, 2015, 10:19:36 AM »
No I have power to the motors. I thought maybe I needed to connect a enable pin so I connected pin 1 on one board to pin 1 on the other (parallel port) but that didn't work. This is why I was trying to understand every pin that mach uses on the parallel port. Thanks for your help especially because its more of a electronic problem and not mach per se. Art
