Hello Guest it is November 22, 2026, 06:30:53 AM
Author Topic: Setting Machine Coord's and Offsets  (Read 10359 times)
« on: March 04, 2015, 07:07:59 AM »
Can anybody provide information on setting machine coord's.  I guess it needs to be set on the offset tab, but can't figure it out.  Even if somebody can point me to a book or learning outlet it would be helpful.
Re: Setting Machine Coord's and Offsets
« Reply #1 on: March 04, 2015, 07:42:18 AM »
For a book  I would suggest CNC Programing by Peter Smid. There is a lot to be found in the Mach Manuals also.
« Reply #2 on: March 04, 2015, 07:51:52 AM »
Machine coordinates are zeroed when you home the machine. There is no other way to manipulate them.
Although you can specify the position when homing, if you want the home switch position to be something other than 0.
« Reply #3 on: March 04, 2015, 09:24:38 AM »
FWIW, some info on offsets
« Reply #4 on: October 22, 2015, 07:27:17 PM »
Anyone have any idea way V.I.D and product id have to be reinstalled over and over ??? For an xbox controller using Lee Davis Plug in.
