Hello Guest it is November 24, 2026, 07:03:00 AM
Author Topic: Mach4 cw button question  (Read 8673 times)
« on: February 28, 2015, 09:48:43 AM »
Can someone help me with a dumb question in Mach4 with spindle cw I have my router set up on a ssr to pin 17 and im using Darwin to control Gecko G540 it all works as it should if i manually hit the spindle cw button in Mach4 it turns on and off as it should, but if i call up a M03 it doesn't work. I can call a M03 in MDI and the history says single sent to pin 17 but no happiness. But if I go and manually hit the spindle cw button in Mach4 it works. I've been reading the forums in Mach4 spindle search but can't figure it out.
Thanks for your time.
Offline dude1
  •  1,253 1,253
Re: Mach4 cw button question
« Reply #1 on: February 28, 2015, 01:49:36 PM »
remove the M3, M4, M5 from the macro folder it should come right after that
« Reply #2 on: February 28, 2015, 02:21:49 PM »
daniellyall
 ;D Thank you very much that works great! I would have never found that I've been pulling my hair out for the last two days ;D.
Offline dude1
  •  1,253 1,253
« Reply #3 on: February 28, 2015, 02:22:26 PM »
be there done that
