Hello Guest it is October 21, 2026, 08:58:27 AM
Author Topic: Mach 3 install On windows xp embedded issue.  (Read 9765 times)
« on: February 27, 2015, 12:17:07 PM »
Hello All  I am new to this Forum.  I have been lurking around for a while.  I finally decided to plunge into mach3.  I have tried to install Mach3 on a dell optiplex fx160.  I am having trouble with an error.  I get the error.
Mach3.exe entry point not found
the procedure entry point_except_handler4_common could not be located in the dynamic link library msvcrt.dll.    i am thinking this is a microsoft visual c runtime  library.
i have updated the .net framework as it was version 2.0.  i updated to 3.5 sp1.  but still the error.
i have reinstalled mach 3 twice but still this problem.  has anybody seen this or at least point me in the right direction.
Thanks in advance.
Marcus
Re: Mach 3 install On windows xp embedded issue.
« Reply #1 on: February 27, 2015, 09:12:16 PM »
I don't know, Marcus, but what I would try is to search your pc for msvcrt.dll, see what version it is, then google msvcrt.dll and see if you can find a later (or earlier) version.
« Reply #2 on: April 01, 2015, 06:54:31 PM »
well its been a while.  I have been out of town traveling and i finally got some time to get this fixed.  i ended up buying a mount for the internal hard drive as mine only had the svram.  I mounted the hard drive and installed windows 7 32 bit.  Got rid of embedded and installed Mach 3 now its working fine.  I didn't have too much experience with embedded xp, and the svram was giving me a lot of trouble.
let the fun begin ;)
