Hello
Guest
it is
November 24, 2026, 06:08:24 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Mach 3 install On windows xp embedded issue.
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach 3 install On windows xp embedded issue. (Read 10045 times)
Marcuss
2
on:
February 27, 2015, 12:17:07 PM »
Hello All I am new to this Forum. I have been lurking around for a while. I finally decided to plunge into mach3. I have tried to install Mach3 on a dell optiplex fx160. I am having trouble with an error. I get the error.
Mach3.exe entry point not found
the procedure entry point_except_handler4_common could not be located in the dynamic link library msvcrt.dll. i am thinking this is a microsoft visual c runtime library.
i have updated the .net framework as it was version 2.0. i updated to 3.5 sp1. but still the error.
i have reinstalled mach 3 twice but still this problem. has anybody seen this or at least point me in the right direction.
Thanks in advance.
Marcus
Logged
grouchy
11
Re: Mach 3 install On windows xp embedded issue.
Reply #1 on:
February 27, 2015, 09:12:16 PM »
I don't know, Marcus, but what I would try is to search your pc for msvcrt.dll, see what version it is, then google msvcrt.dll and see if you can find a later (or earlier) version.
Logged
Marcuss
2
Reply #2 on:
April 01, 2015, 06:54:31 PM »
well its been a while. I have been out of town traveling and i finally got some time to get this fixed. i ended up buying a mount for the internal hard drive as mine only had the svram. I mounted the hard drive and installed windows 7 32 bit. Got rid of embedded and installed Mach 3 now its working fine. I didn't have too much experience with embedded xp, and the svram was giving me a lot of trouble.
let the fun begin
Logged
Print
Pages:
1
Go Up
« previous
next »
