Hello Guest it is November 13, 2026, 11:52:37 AM
Author Topic: Mach3 Wizzards not working out as planned  (Read 20120 times)
Re: Mach3 Wizzards not working out as planned
« Reply #10 on: February 24, 2015, 03:38:40 AM »
I can assure you it is not the correct xml or I would not ave seen it was a pirated version.
If you look on the first page in Mach you will see the profile name, you need to look for a XML with that name.
« Reply #11 on: February 24, 2015, 04:25:42 AM »
ok, once i'm back at the machine i will try to find the correct XML and post it here. not sure it will be today, i hope we can pick this up later on.
have a good one.
« Reply #12 on: February 24, 2015, 04:27:37 AM »
ok
