Mach Discussion => General Mach Discussion => Topic started by: PeterJensen on February 21, 2015, 10:42:09 AM
Hello, i just purchased mach3 after using the demo for several months.
I had hoped that the registered version would have better working wizzards, but i find that there are still many wizzards that i simply cannot use.
Im talking about the wizzards that come with mach3 not the extra add-on once.
For example the "circular bolt pattern" when i press "post code" i always get the error "Line 27 mismatch" but it wont even show me the code, so
i cannot even debug and whats wrong with line 27. I have issues like this with several wizzards, are anyone else having these issues?
Or what do i do to fix it?
Peter,
Much as I like Mach 3 as a controller and worked for several years writing G code I think that manual programming is a thing of the past. I got CamBam and in a short time I got to where I import or draw a little, select some operations and enter some data, view the toolpaths and cut metal. Most of the time I don't even dry run. I also then have a file I can run again, and can change tool sizes and such with a simple toolpath regeneration. I have CamBam on the same computer as Mach3.
Peter I just checked it here and it works fine. Could you post a Picture of your settings for that page.
Hello, i made screenshots, any input you might have could be very helpfull :-)
Screen 1: https://dl.dropboxusercontent.com/u/267455/tt/20150223_172050.jpg
Screen 2: https://dl.dropboxusercontent.com/u/267455/tt/20150223_172057.jpg
Can you attach your xml please.
Here is the xml file that contains my settings:
https://dl.dropboxusercontent.com/u/267455/tt/Mach3Mill.xml
Works fine here with your setting and xml although I see you are using a pirated version of Mach.
no no, i upgraded from that version of mach3 to a bought version, see screenshots.
I'm fully licenced and legal now.
Well the xml you attached is the wrong one.
Please attach the correct one so I can test with the configuration you are currently using.
could that be the issue? because that is the xml i am currently using.
I can assure you it is not the correct xml or I would not ave seen it was a pirated version.
If you look on the first page in Mach you will see the profile name, you need to look for a XML with that name.
ok, once i'm back at the machine i will try to find the correct XML and post it here. not sure it will be today, i hope we can pick this up later on.
have a good one.
ok
