Hello
Guest
it is
November 13, 2026, 03:14:15 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Save current tool position so I can come back to it?
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Save current tool position so I can come back to it? (Read 18536 times)
bitviper
11
on:
February 20, 2015, 06:17:47 PM »
I'd like to be able to call a routine that moves the mill somewhere and then, when the routine is done, I'd like the mill to return to where it was before the routine was called. Is that possible?
Overloaded
4,923
Re: Save current tool position so I can come back to it?
Reply #1 on:
February 20, 2015, 06:25:29 PM »
There is "Remember" and "Return" that might be what you want.
OEM 286 & 285 that you could build into a button script.
Russ
bitviper
11
Reply #2 on:
February 20, 2015, 06:27:02 PM »
Ah - thanks for the reply but I want to do it automatically in my code. The routine is called many times and I'd have to hang around throughout the job to press that button.
No way to do this in code?
Overloaded
4,923
Reply #3 on:
February 20, 2015, 06:29:07 PM »
Sure, could be done in a macro, then called with M****
bitviper
11
Reply #4 on:
February 20, 2015, 06:30:34 PM »
Ok. I'll look into how to use OEM codes in gcode. Will report back here when I figure it out and have working code.
Overloaded
4,923
Reply #5 on:
February 20, 2015, 06:30:54 PM »
or, how bout a subroutine, then a return ?
bitviper
11
Reply #6 on:
February 20, 2015, 06:31:48 PM »
I do use a subroutine already and it returns to the main program when it is done. Trouble is, the tool doesn't automatically return to where it was before the routine was called.
ger21
6,295
Reply #7 on:
February 20, 2015, 06:51:57 PM »
SetVar(1, GetOEMDRO(800))
SetVar(2, GetOEMDRO(801))
SetVar(3, GetOEMDRO(802))
Do Stuff Here
Code "G0 Z" & GetVar(3) ' Move to Previous Z Position
Code "G0 X" & GetVar(1) & " Y" & GetVar(2) ' Move to Previous XY Position
bitviper
11
Reply #8 on:
February 20, 2015, 06:54:29 PM »
Thanks. Are those lines going into my gcode file or in something else? I'm doing a lot of hunting regarding these OEM codes and they refer to VB scripting but I haven't found yet how that relates to the gcode file.
ger21
6,295
Reply #9 on:
February 20, 2015, 06:58:42 PM »
They need to go into an M code macro. I was assuming that's where you're "routine" was.
Print
Pages:
1
2
Go Up
« previous
next »
