Hello Guest it is November 13, 2026, 03:05:13 PM
Author Topic: Save current tool position so I can come back to it?  (Read 18535 times)
« on: February 20, 2015, 06:17:47 PM »
I'd like to be able to call a routine that moves the mill somewhere and then, when the routine is done, I'd like the mill to return to where it was before the routine was called.  Is that possible?
Re: Save current tool position so I can come back to it?
« Reply #1 on: February 20, 2015, 06:25:29 PM »
There is  "Remember" and "Return" that might be what you want.
OEM 286 & 285 that you could build into a button script.
Russ
« Reply #2 on: February 20, 2015, 06:27:02 PM »
Ah - thanks for the reply but I want to do it automatically in my code.   The routine is called many times and I'd have to hang around throughout the job to press that button.
No way to do this in code?
« Reply #3 on: February 20, 2015, 06:29:07 PM »
Sure, could be done in a macro, then called with M****
« Reply #4 on: February 20, 2015, 06:30:34 PM »
Ok.  I'll look into how to use OEM codes in gcode.  Will report back here when I figure it out and have working code.
« Reply #5 on: February 20, 2015, 06:30:54 PM »
or, how bout a subroutine, then a return ?
« Reply #6 on: February 20, 2015, 06:31:48 PM »
I do use a subroutine already and it returns to the main program when it is done.  Trouble is, the tool doesn't automatically return to where it was before the routine was called.
« Reply #7 on: February 20, 2015, 06:51:57 PM »
SetVar(1, GetOEMDRO(800))
SetVar(2, GetOEMDRO(801))
SetVar(3, GetOEMDRO(802))
Do Stuff Here
Code "G0 Z" & GetVar(3) ' Move to Previous Z Position
Code "G0 X" & GetVar(1) & " Y" & GetVar(2) ' Move to Previous XY Position
« Reply #8 on: February 20, 2015, 06:54:29 PM »
Thanks.  Are those lines going into my gcode file or in something else?  I'm doing a lot of hunting regarding these OEM codes and they refer to VB scripting but I haven't found yet how that relates to the gcode file.
« Reply #9 on: February 20, 2015, 06:58:42 PM »
They need to go into an M code macro. I was assuming that's where you're "routine" was.
