Hello Guest it is November 13, 2026, 04:35:38 PM
Author Topic: Grizzly lathe retrofit!!!  (Read 8975 times)
« on: February 15, 2015, 08:43:31 PM »
Guys,
I've been studying on purchasing a 10 x 22 grizzly lathe and retrofitting it. I've stumbled upon some small lathe work that would be a perfect fit for it. Also I think I need one
Re: Grizzly lathe retrofit!!!
« Reply #1 on: February 16, 2015, 02:17:35 AM »
If it has a variable speed motor then likely it has a VFD already, either that or it is a DC motor and even then it must have a speed controller if it is variable speed.
Regarding the CSMIO, just make sure it is either an IP-A or IP-S if you want threading as the IP-M cant do Lathe threading, or for that matter rigid tapping.
« Reply #2 on: February 16, 2015, 08:54:00 AM »
Yep. I was planning on the stepping up a notch on the controller this time. Definitely want to be able to thread.
