Hello Guest it is October 24, 2026, 03:30:43 PM
Author Topic: csmio/ip-a encoder wiring  (Read 10173 times)
« on: February 15, 2015, 05:06:32 PM »
I have mr-j3-60a amps (Mitsubishi) and a csmio/ip-a controller. I know that the encoder wire go to the amp input then to the controller from the amp output. I have got the six wires for the  A- ,A+ ,B- , B+, Z- ,Z+ . what I dont understand is where does the +5 volt and ground come from.
Re: csmio/ip-a encoder wiring
« Reply #1 on: February 16, 2015, 02:46:48 PM »
You do not need 5v and Gnd, they are there so that you can power an encoder if you have a separate encoder. Your encoder is already powered by the drive. You may need to connect the Gnd to the Gnd of the drives I/O but most likely you will not.
« Reply #2 on: February 16, 2015, 04:03:12 PM »
Thanks Hood !!!!   Your help is greatly appreciated .
