Hello Guest it is October 02, 2026, 05:20:33 AM
Author Topic: CamBam to Mach3  (Read 8613 times)
CamBam to Mach3
« on: February 15, 2015, 12:12:00 PM »
When I generate gcode in CamBam the files are larger when loaded into Mach3.
Thanks in advance for any help!!
Gayle
Re: CamBam to Mach3
« Reply #1 on: February 15, 2015, 02:53:16 PM »
Maybe draw the part smaller  ;D  sorry could not help it.
Make SURE your drawing units (inch, MM) are the same for both Programs.
Check the output Gcode for a G20(inch) or G21(mm) reference .
Re: CamBam to Mach3
« Reply #2 on: February 15, 2015, 03:21:53 PM »
Also make sure you are using the correct post processor.
If your like me, all my files are realy small ......only do one line at a time ???.....just jesting with ya! :) ;) :D ;D
Re: CamBam to Mach3
« Reply #3 on: February 15, 2015, 04:23:31 PM »
 :D
