Hello Guest it is September 05, 2026, 10:10:12 PM
Author Topic: Any German speakers here  (Read 20242 times)
« on: April 09, 2007, 04:19:23 PM »
Have been trying to help out a member here but afraid I just cant make head nor tail of his machines pinouts as the PDF is in German and also the handwritten notes are in German.
 Any help much appreciated.
Offline klmark
  •  107 107
Re: Any German speakers here
« Reply #1 on: April 09, 2007, 04:58:19 PM »
Hi
I would like to have a look at it see if I can be any help I mostly talk german who know i will try to help
    E-mail address   bwshop@gmail.com
« Reply #2 on: April 09, 2007, 05:04:37 PM »
Thanks, have emailed them to you.
« Reply #3 on: April 10, 2007, 02:57:48 AM »
Hi
I`m living in Germany and use Mach since 3 years. If i can help you with my bad english here my E-Mail ad.: dampfhannes@googlemail.com
Greet`s
Hannes
ynneb
« Reply #4 on: April 10, 2007, 03:20:31 AM »
Offline klmark
  •  107 107
« Reply #5 on: April 10, 2007, 11:25:53 AM »
Hi
Sorry I don't under stand every thing that is writhing there are some warning in there that I don't quite understand so I will try to help what do you need to know
« Reply #6 on: April 10, 2007, 12:43:32 PM »
Thanks for the replies, this is a link to Anthony's original post http://www.artsoftcontrols.com/forum/index.php?topic=2892.0
 I have also attached all of the docs that are available and if anyone can help out I am sure Anthony would be most grateful.
Offline klmark
  •  107 107
« Reply #7 on: April 10, 2007, 03:58:05 PM »
Hi
What dose he need to know I do understand some of it but not every thing Let me know
« Reply #8 on: April 10, 2007, 04:01:51 PM »
Basically he is needing to know the pinouts for everything so he can assign them in Mach, he asked if I could do an xml with the info but afraid I couldnt make head nor tail of it.
Offline klmark
  •  107 107
« Reply #9 on: April 10, 2007, 04:31:41 PM »
Hi
Here is what I find pin 2 x dir pin 3 x step pin 4 y dir pin 5 y step pin 6 z dir pin 7 z step pin 8 w dir pin 9 w step pin 10 z limitswitch pin 12 y limitswitch pin 13 x limitswitch pin 15 w limitswitch  pin 1 is pilot relay pin 14 is pilot relay #2 see if that will help let me know
