Hello Guest it is November 27, 2026, 06:42:04 AM
Author Topic: Setting up limit/home switches for lathe  (Read 9127 times)
« on: February 07, 2015, 10:27:37 AM »
Hello,
Sorry if this has been covered.  Tried to search but I'm finding mostly info on mill setups and I want to make sure I understand it for my lathe.
I have image showing how I think the switches should be wired with the C10 BOB.  I also have a screen cap of the ports and pins dialog.
I'm not sure about what to put in the boxes under the columns for port# and pin#.
Can some one take a look and let me know if I am on the right track?
In addition, can I use the E-Stop on my G0602 lathe has an E-Stop for both the lathe spindle and the stepper motors by adding the wires to the C10?
Re: Setting up limit/home switches for lathe
« Reply #1 on: February 07, 2015, 02:12:40 PM »
You would enter Port as 1, assuming of course you are not using a secondary port.
Not sure about the E-Stop, it depends how many poles it has and whether they are already used.
« Reply #2 on: February 07, 2015, 05:59:50 PM »
Thanks Hood
