Hello Guest it is November 13, 2026, 02:13:15 PM
Author Topic: ePID fault... press RESET on MACH screen" error with CSMIO-IP-M  (Read 74416 times)
Re: ePID fault... press RESET on MACH screen" error with CSMIO-IP-M
« Reply #10 on: April 11, 2016, 02:20:16 PM »
Hey guys the CSLAB support has helped me to solve the problem.
What you have to do is.
Install the version 03.043.022. and DONT use the old .XML file.
It worked for me !
Best regards
« Reply #11 on: April 11, 2016, 03:24:27 PM »
Interesting their choice of version, that was the version I found out did Lathe threading without the delay in pull out. The Spindle Override however did not work in that version and I think it was also prior to the Lathe Tool DRO that Brian added for me.
« Reply #12 on: April 13, 2016, 11:14:13 AM »
Will try all the other functions see if it works. I have another question about probe inputs. I have two things the 3D touch probe and the auto tool zero. How do i use two different inputs ? is tis possible or do i have to connect the auto tool zero and 3D probe to the same pin ?
Best regards
Slovenec
« Reply #13 on: April 15, 2016, 09:12:01 AM »
I have never used a probe or auto tool zero so not really sure but I would imagine if they are both using G31 (M31) then you will need to connect to the same Input.
