Hello Guest it is September 17, 2026, 08:35:40 PM
Author Topic: Mouse freezing on windows XP  (Read 90494 times)
« on: February 02, 2015, 07:25:36 PM »
My mouse stops working when my mill is cutting. If I leave the CNC table disconnected and run the program the mouse doesn't lock up,when I plug the table in and run it the mouse stops working until machine has finished its run. I am running XP PRO 32 bit SP3, CPU Intel core 2 Duo 2.66GHZ, Ram 1.0 GB, video card is GE FORCE 210 1.0 GB. I have tried everything can some one please advise me? My CNC is a TONSEN 3040C H80 with stepper motors and DC spindle cable drive.
Thanks in advance.
Mick :)
Re: Mouse freezing on windows XP
« Reply #1 on: February 02, 2015, 07:52:04 PM »
I would suggest you not play with your mouse when running a program as Mach shares time with windows.
Also suggest a not using a wireless mouse.
Just my opinion......,
« Reply #2 on: February 02, 2015, 08:02:14 PM »
Your CNC table is emitting EMI and the wireless mouse receiver is receiving the EMI noise signal with the mouse signals and getting confused, the mouse driver(s) are locking up.
« Reply #3 on: February 02, 2015, 08:44:18 PM »
My mouse is USB connected not wireless.
« Reply #4 on: December 19, 2015, 11:04:04 PM »
why not use a wireless mouse?
« Reply #5 on: December 20, 2015, 12:03:54 AM »
Mick1969,
Don't play with your mouse even if USB connected. Same reason as reply #1.
sebashtionh,
Some folks have no problems with a wireless mouse. I have had problems with a wireless at times depending on what I was doing.
Never a problem with direct connected. Reply #2 is just one example of what can happen, ie; something can interfere with the mouse receiver.
I don't play with my mouse as others do when running a program! Leave it alone. Same can happen with a wireless keyboard.
Remember that you are running a machine and want as solid as possible a connection to control it.
Just my opinion,
« Reply #6 on: December 20, 2015, 01:11:12 AM »
Have upgraded computer to Windows 7 with 4 gig  ram and 4 gig hard drive had no problems since.
In XP cnc table started freezing as well.
