Hello Guest it is November 13, 2026, 03:15:25 PM
Author Topic: x axis only moves negative  (Read 8185 times)
« on: January 28, 2015, 02:55:53 PM »
Hoping someone can help..
My X axis works fine when using the arrows on the keyboard. right arrow x moves positive..left arrow x moves negative.
The problem is when I start the gcode. The x only moves negative. the DRO shows a positive movement, but i is traveling negative.
I am using stepper motors and a LPT BOB. Have changed BOB, but same problem. I even thru on another stepper driver and still same problem.
Re: x axis only moves negative
« Reply #1 on: January 30, 2015, 08:06:06 AM »
Attach your xml and the G Code you are having issues with and maybe the problem can be found.
