Mach Discussion => General Mach Discussion => Topic started by: bopierce on January 28, 2015, 03:55:53 PM
Hoping someone can help..
My X axis works fine when using the arrows on the keyboard. right arrow x moves positive..left arrow x moves negative.
The problem is when I start the gcode. The x only moves negative. the DRO shows a positive movement, but i is traveling negative.
I am using stepper motors and a LPT BOB. Have changed BOB, but same problem. I even thru on another stepper driver and still same problem.
Attach your xml and the G Code you are having issues with and maybe the problem can be found.
