Hello Guest it is October 20, 2026, 03:48:31 PM
Author Topic: How to swap the x and y axes  (Read 11517 times)
« on: January 27, 2015, 02:47:02 PM »
Hi
I`d like to swap my x and y axes in mach 3. Do I just switch the motor specs in the motor
tuning section of Mach 3. In addition do I need to switch the connectors to the motors
and switch the step and direction from the Gecko 320s to the BOB.
Re: How to swap the x and y axes
« Reply #1 on: January 30, 2015, 06:58:14 AM »
Hi
I found the answer. I switched the x and y pins in motor outputs and switched
the specs in motor tuning. I believe switching the motor tuning was necessary
because each motor has a different pulley ratio for the servo motors.
It was not necessary to switch the motor connectors or switch the step,direction
and commons from the Gecko to the BOB
« Reply #2 on: January 30, 2015, 11:32:18 PM »
when your done, save this setup as a different profile, then when you start mach3, you can choose which orientation you want to load
« Reply #3 on: February 10, 2015, 02:31:40 AM »
i dont see the specs. in motor tuning. can you tell me where they are?
any help
Saab
« Reply #4 on: February 10, 2015, 07:22:37 AM »
Hi
I was not clear. What I meant was the settings for motors velocity and acceleration. Which
are user defined.
