Hello Guest it is October 25, 2026, 04:59:59 PM
Author Topic: Connection Failed. CSMIO/IP not found.  (Read 21661 times)
« on: January 25, 2015, 08:51:44 PM »
Hello,
Anyone have any problems with getting their CSMIO/IP-A to connect?
I have the latest version of Mach 4 and the latest Plugin for the Control card.  I ran down through the set up procedure in the Cs Lab setup guide still no luck.
I'm connecting direct to my computer with a crossover cable.
I've disabled my firewall.
I've set up the correct I.P. and Mask Addresses.
I'm running windows 7 and it's not Genuine (hope this isn't a problem ;))
When I change the TCP/Ipv4 settings and start the CS Labs board my Local Area Connection's status changes to "device unrecognized" (or something to that effect)...
Any help would be much appreciated!
Best
~Josh
Offline TPS
  •  2,627 2,627
Re: Connection Failed. CSMIO/IP not found.
« Reply #1 on: January 26, 2015, 03:32:03 AM »
are you able to ping the CSMIO ?
Thomas
« Reply #2 on: January 26, 2015, 05:46:57 AM »
Thomas,
The ping test was successful. 4 packets sent 4 received 0 lost.
The csmos blinked 4 times.
Bear in mind this was my first ping test, I did it from cmd.
~Josh
Offline TPS
  •  2,627 2,627
« Reply #3 on: January 26, 2015, 06:13:22 AM »
have you been able to do the firmwareupdate with this PC ?
sorry i have only experience with mach 3 and cslab, not on mach4.
Thomas
« Reply #4 on: January 26, 2015, 12:47:51 PM »
Have you got both parts of the plugin in the plugins folder?
« Reply #5 on: January 26, 2015, 01:03:29 PM »
I'll be looking and testing as soon as I get home from work.
Thanks guys!
~Josh
« Reply #6 on: January 26, 2015, 05:10:24 PM »
Alright I got it going.
I didn't have the correct plugins installed I had "_C" instead of "_A".  I looked to make sure I had both plugins in the folder and that's when I noticed, Thanks Hood!
Thanks for the pinging information Thomas!
I should be wiring up my machine sometime this week I'll keep you guys posted.
Thanks again, I'm sure I'll have more questions.
Josh
« Reply #7 on: March 21, 2015, 01:40:16 AM »
Thomas
Hi, please tell me how to ping it. i tried to ping csmio using cmd mode, but it was wrong. can you please help me?
best regards, Jun
Offline TPS
  •  2,627 2,627
« Reply #8 on: March 21, 2015, 02:59:19 AM »
Hi Jun,
ping in a cmd is ok.
dont know your network, if there is no dhcp server the CSMIO
has normaly 10.1.1.2 subnet 255.255.255.0  just make sure that you (pc) is in the same
network.
check your ip by CMD -> IPCONFIG
Thomas
