Hello Guest it is November 13, 2026, 09:39:30 AM
Author Topic: XML FILE WONT LOAD  (Read 12007 times)
XML FILE WONT LOAD
« on: January 25, 2015, 03:38:16 AM »
1st Question on forum ???
I'm tying to load my router profile to a new PC , i have the licence working but when I load the profile & try to open it with the profile loader,  I get the base screen with the file , config headers ect  but no operation screens ?
if i look at the ports & pins the profile  looks correct
i change the extension to xml & place it in the C/:Mach3 folder & removed all xml files from the xml folder, i have tried several times but still cant get it to work
Any help would be appreciated
Rick
Re: XML FILE WONT LOAD
« Reply #1 on: January 25, 2015, 03:59:49 AM »
Sounds like you may have had a custom screenset loaded in that xml.
Go to View menu then Load Screens then choose the 1024.set or whatever from the Mach3 folder.
« Reply #2 on: January 25, 2015, 06:01:57 AM »
im going from a  version from 2002( will check) to the latest as well
Rick
« Reply #3 on: January 25, 2015, 06:09:22 AM »
Make sure the name of the .xml doesn't have any spaces in it, or it won't work from a desktop shortcut.
« Reply #4 on: January 25, 2015, 03:40:26 PM »
Ok now sorted,as Hood suggested load screen , as I was going from R2.63 the later version didnt have that screen set
Loaded the 1024.set & its now working
1 more question can I load that screen set to the old version just to keep them looking the same ?
Thanks for the help
Rick
« Reply #5 on: January 26, 2015, 12:45:28 PM »
You can load any screen into Mach as long as it is a Mach compatible screen.
Where you may hit snags is features have been added through the versions for such things as Image buttons and LEDs.
I do not think the standard screenset uses them though, so you should be ok.
