Hello Guest it is October 25, 2026, 12:26:56 AM
Author Topic: Steps to making mill bulletproof  (Read 23825 times)
Offline BarryB
  •  267 267
« on: January 11, 2015, 05:06:23 PM »
Hello, I just had a horrible day using the mill.  It kept crashing about every 3 minutes.  I'm running it on a laptop through a sub smooth stepper, the cnc4pc breakout board, and gecko drive motion controllers.  The mill is large about the size of a car, and six axis.  The frame is 8020, hsd spindle, b/c head, a table rotor and gantry system.  I'd like to make this bulletproof, so I can do real work on it.  Right now, I can't.  Anybody have steps to build on, test with, so I can depend on this thing?  If anybody is in the OC area and would like to lend a hand, I'd love it.
I know scales are all working, and all axis work.  Nothing is reliable though.
Wits end, argh!
Re: Steps to making mill bulletproof
« Reply #1 on: January 11, 2015, 08:57:48 PM »
Hi BarryB:
Sounds like an interesting machine, and must be impressive with six axis going. The problem is most likely noise , and with six axis motor cables running around, that makes for a lot of little "antenna's" out there to pick up stuff. Also, a vfd generates a lot of noise as you know.
The usb version of the SS is not as noise resistant as the ethernet version for starters. The general run of the mill USB cables are not very good for shielding, so you should definitely get the highest quality USB cable for the SS. Another simple addition would be to put those "chokes" on all the cables. You can get the clamp on type at Radio Shack, and put them on both ends of cables. Most newer electronics have chokes on the power cables as you may have noticed. Another requirement for a CNC machine is a copper grounding rod driven into the earth, and all the grounds from the shields connected to the copper rod with RG8 shielded cable stripped back to expose the woven shielding; solder copper lugs to the ends, and connect the machine cable shields to the copper rod with those braided type cables. This kind of woven cable is better than a single wire for noise, as it is a function of area, to carry the high frequencies. Do a search for how different machine builders have addressed the noise problem with their motor controllers/VFD's. Really good machine grounding goes a long ways to insure machine stability. Another source of noise is a TIG welding machine. They can emit high frequencies onto the building wiring, even if it is not in your shop. It doesn't take too much to upset the tiny 5v step/direction signals going to the motor amps, or the limit switch signals.
I am not in OC, but am not too far away, but am fairly busy for the next few weeks.
John
Offline BarryB
  •  267 267
« Reply #2 on: January 11, 2015, 09:08:28 PM »
Thanks John.  As you can tell, I'm crazy fed up.  I'll go out and get those chokes and a higher quality USB cable.  There is a ground going from the frame of the machine to common ground for the house.  You mention 'grounds from the shields'.  I'm not sure what that means.  Hmm, do you mean the woven shielding in a cable?  Perhaps that's part of my issue, my motor wire isn't shielded.  The spindle wire is, but the motor wire isn't.  Perhaps I should rewire this thing on top of this.
Barry
Offline BarryB
  •  267 267
« Reply #3 on: January 11, 2015, 11:15:07 PM »
I'll go ahead and order more cable and rewire.  This is the wire I was thinking of ordering for the motors.
http://www.wireandcabletogo.com/18-AWG-4-Conductor-Communication-Cable-Foil-Shield-500ft-or-1000ft-Spool.html
Think it's up to the task?
I'm asking what are probably dumb questions, but I really don't want to have a mill crash session again.  I've gotten to not trust it.
Barry
Offline derek
  •  200 200
« Reply #4 on: January 12, 2015, 05:18:10 AM »
I would try a different brand of drive on one axis and see if that helps.
I had Gecko drives on my first router and suffered the same kinds of problems. Everything had to be perfect electronically for them to be dependable. I'm not slamming the drives as they are very popular, just relaying what worked for me.
« Reply #5 on: January 12, 2015, 01:32:46 PM »
Can you explain what you mean by the mill crashing.
« Reply #6 on: January 12, 2015, 02:21:12 PM »
Hi Barry:
Yes, the shielding on the cables must be connected to a common ground. All the ground wires should terminate at a single, common point.
It would be best if the ground was terminated in a copper rod driven into the ground. You can get such copper grounding rods from Grainger, and also Electrical supply houses. The rods are usually about 4 to 5 feet long, and about 5/8" diameter. The spindle motor cables must absolutely be enclosed within shielded cable, and also connected to the common ground.
I mentioned the RG8 co-ax cable because it has a braided shielding. Strip back the plastic for about 6 or 8 inches each end, and cut back the inner wire. Then solder a lug for a #10 size screw on each end. Use these braided ground cables to link to your copper rod from the other machine cables. The braided cable has more area than a single copper wire, and the hi-frequency noise is conducted away due to the larger surface area of the braided cable. Using the house ground is depending on a single copper wire to go to ground, and not as efficient or effective as the copper rod/braided cable method.
Both of my commercial CNC milling machines have a copper rod just outside the building, close the the machine locaton, with a very large copper cable connecting the machine ground. The have been very problem free.
Another possible source of noise proofing your machine would be to convert all your limit/home switches to 24 volt, and drop to 5v just at the breakout board with opto-couplers. The potential between the signal and ground is nearly 5 times what the 5v signal is, and is much more noise resistant. All commercial machines use 24v signal wiring.
John
« Reply #7 on: January 12, 2015, 05:57:29 PM »
Hi Barry:
I forgot to say, the wire with shielding you have the link to is excellent quality. Two conductor would be good for limit switch wiring, but 22 ga would be sufficient for limit/home signals, as that is very low current.
John
« Reply #8 on: January 12, 2015, 08:59:02 PM »
Damnit! I absolutely hate when I see advice to drive a ground rod to solve a noise problem on a machine. If that works it only proves that you have a problem you don't understand and are clueless about how to actual fix it!  Sorry for the harsh words but I have seen this kind of bad advice since the first days of PCs, computerized cash registers etc.  If you ever get this kind of advice from the manufacturer of any kind of electrical machine you should be very afraid working around it because it  very well could run amok and hurt you!
A 90 hr week I'm bit grumpy.
« Reply #9 on: January 12, 2015, 10:53:22 PM »
Hi garyhlucas:
Sorry you are in a mood to curse my discussion of ground problems, and/or me personally. Electrical noise is present in CNC machines due to many sources; variable frequency drives create hi-frequency noise for one. It is invisible, it is silent, it is elusive, and it can cause problems with computer signals and circuits.
 You said "If that works it only proves that you have a problem you don't understand and are clueless about how to actual fix it!"
I would say," If that works it only proves electrical noise was the problem."
AC wiring does have a ground path built into the system, but a direct ground for a machine frame with a shorter path than the building wiring is not going to cause all hell to break loose, and make the CNC machine run amok and hurt people; however you are certainly entitled to your opinion, and your obvious rage.
As far as getting this advice from a manufacturer, I personally know of (4) CNC commercial brand new (within the last year) milling machines and lathes, installed by licensed electrical contractors, that put a copper ground rod through the concrete floor, near the machine for an additional ground, before the machine was even turned on. I suppose you would call them idiots. All of these machines work without problems of any kind; they don't even "run amok!"
In conclusion, I would say, lighten up Gary, were on this forum to offer advice to fellow machinists trying to get their CNC Mach3 driven machines running happily, and without problems; no need to get angry.
John
