Hello Guest it is September 27, 2026, 06:59:05 PM
Author Topic: Help A axis slaved to Y homing problem  (Read 19345 times)
« on: January 06, 2015, 08:44:45 PM »
I have a Shapeoko 2 CNC mill with a dual Y stepper axis.  I have the A axis slaved to Y and I can jog all axis with no problems but when the Y axis tries to home the A and Y don't work in unison.  I tried setting RefCombination(10) in the 1024.set file but that did not help.  Please advise. I have a license copy of Mach3.
Re: Help A axis slaved to Y homing problem
« Reply #1 on: January 06, 2015, 09:14:13 PM »
Do the Y and A have separate home switches, or do you just have one?
In General Config, there's an option for "Home Slave with Master".
Check it if you have one switch, uncheck it if you have two switches.
« Reply #2 on: January 07, 2015, 09:49:53 AM »
Just one home switch.  Y and A both drive the Y axis in a gantry system.
« Reply #3 on: January 07, 2015, 09:54:54 AM »
Did you have Home Slave with Master checked?
Is this with the parallel port, or a motion controller?
« Reply #4 on: January 07, 2015, 10:11:27 AM »
I haven't checked yet but probably not.  I'm using a UC-100
« Reply #5 on: January 07, 2015, 04:31:15 PM »
The external controller will be responsible for the slaved homing so probably best to contact the CNCDrive and see if they can help you out.
« Reply #6 on: January 07, 2015, 04:43:25 PM »
Hmm,  well I guess I could connect directly to the parrell port.
« Reply #7 on: January 07, 2015, 05:23:45 PM »
I went back and read the UC-100 documentation and if I understood right all I need is the C10 breakout board?  I currently have the UC-100 going to a C10 breakout board which is connected to 4 DRV8825 stepper drivers.  Are the DRV8825 drivers necessary?
« Reply #8 on: January 08, 2015, 02:48:09 PM »
You need stepper drivers if you have steppers. The UC100 is a motion controller, it recieves info from Mach and outputs pulses to the stepper drives which in turn move the motors.
The breakout board is simply giving you an easy means of connecting things.
« Reply #9 on: January 08, 2015, 02:49:41 PM »
Well I'm all good to go then.
