Hello Guest it is October 11, 2026, 10:10:45 PM
Author Topic: Limit switch reset problem  (Read 9224 times)
« on: January 03, 2015, 07:20:30 PM »
Hi
I am rewiring my cnc and have a problem with the limits. I grouped all the limits for the + and – limit direction for
the z and y together. Another set of limits are grouped for the + and – limit directions for the X.
The limits are snap action limits and they are set for active low. When I press the reset it shows that
M1 + and M1- are yellow
M3+ M3- and M3 Home are yellow
It seems when I try to set them for active high the software LED change from yellow to gray. Then I can
reset. But when I open Mach3 for a new session I get the same problem telling me a limit was hit. It seems
I had to fool around with this even before I rewired my control box. In the old control panel each limit
switch was wired separately to the BOB. This new wiring is sharing the BOB inputs for multiple axes.
I`m lost!!
Re: Limit switch reset problem
« Reply #1 on: January 04, 2015, 04:13:32 AM »
If you attach your xml I will take a look.
Also are your switches Normally Closed or Normally Open?
« Reply #2 on: January 04, 2015, 08:58:56 AM »
NC for the limits...thanks for taking a look.
« Reply #3 on: January 04, 2015, 12:05:58 PM »
The only thing I see at the moment is that your X axis Home switch is set to the same port/pin as the A axis switches. Dont really see how that would make a difference but I am presuming that is not the way you have them connected as you dont have the A axis enabled.
