Hello Guest it is October 24, 2026, 09:43:30 PM
Author Topic: Estop w/ 2 Ports  (Read 23072 times)
Offline knucklbustr
  •  9 9
  • Philly Burbs
Estop w/ 2 Ports
« on: January 02, 2015, 09:16:08 PM »
Is there a way to setup Mach3 w/ 2 ports for the Estop  ?
I have 2 ports . Input Signals Config only has 1 Estop setup.
Mach3.
« Last Edit: January 02, 2015, 09:18:40 PM by knucklbustr »
The right hand is always beating up my left hand.
Re: Estop w/ 2 Ports
« Reply #1 on: January 03, 2015, 01:58:23 AM »
It will all depend on the breakout boards you are using, some can easily be linked together so that the E-Stop will disable both breakout boards.
Offline knucklbustr
  •  9 9
  • Philly Burbs
« Reply #2 on: January 03, 2015, 02:35:58 AM »
Gecko 540 for X-Y-A, Port 1,  Pin 10, NC side of Stop Switch
ZTW 5 axis BOB for Z,  Port 2,  Pin 10, NO side of Stop Switch
« Reply #3 on: January 03, 2015, 04:29:48 AM »
Mach, like all other controllers I know of, only has one input for E-Stop. It will be up to you to tie your E-Stop in to your hardware.
For example most industrial machines have an E-Stop string that takes in things such as limits and fault signals from drives etc. Any one of these will not only tell the controller (Mach in this case) but also there will be hardware stops, things such as contactors dropping out the power to the drives or safety relays sending Stop signals to drives etc etc.
 If your breakout can do similar, ie disable all I/O on an E-Stop signal then you may be able to tie things in that way
Offline knucklbustr
  •  9 9
  • Philly Burbs
« Reply #4 on: January 03, 2015, 07:47:46 AM »
In other words, I can only use 1 port for Mach3 estop input, to shut down the Z driver and Gecko 540 .
Maybe tie in the EN+ from the Z driver ?  For me, its a guess for now. Here is the setup for the Z BOB- http://wiki.zentoolworks.com/index.php/Zen_Toolworks_Stepper_Motor_Driver_Breakout_Board(5_Axis_Output_with_on_board_spindle_relay)
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #5 on: January 03, 2015, 07:59:54 AM »
The Mach3 'EStop' input is just to tell Mach3mand EStop occurred. An EStop must function independently of the PC or any circuit board in your machine. On a small machine this can be done by having a suitable EStop in series with a power supply mains feed. On a larger machine you need to use a safety relay/contactor.
Happy machining , Jeff Birt
Offline knucklbustr
  •  9 9
  • Philly Burbs
« Reply #6 on: January 03, 2015, 08:16:30 AM »
Jeff, that made it more clear for me.
Offline knucklbustr
  •  9 9
  • Philly Burbs
« Reply #7 on: January 03, 2015, 12:48:08 PM »
 In your opinion what would be the best route to cutting power to the steppers ?
The 48v PS.  or the drives ?  I have some different electronic relays to incorporate, if needed.
Leaving the A/C motor out.  My E-Stop switch is mechanically hooked to the mill off switch.
The E-Stop switch I have has modules to swapped out. NO and NC.
« Reply #8 on: January 03, 2015, 04:50:32 PM »
Your Estop switch should disconnect the A/C mains power from the 48V power supply. Do not switch the 48Vdc supply with the E-Stop as this may damage the G540.
An example G540 wiring diagram Engineering Note EN010 can be found on this page;
http://www.homanndesigns.com/store/index.php?main_page=page_2
Cheers,
Peter
Homann Designs
Offline knucklbustr
  •  9 9
  • Philly Burbs
« Reply #9 on: January 03, 2015, 10:08:09 PM »
Cheers,
Peter
Looks better than my drawing .  Thanks !
Hard time understanding this, is that a manual switch for the pin 10 enable ? Instead of running thru estop.
And... why the RL-04 48/240 relay, goes to pin 6 output ?  Whats #6 for ?
Right now I have a light switch to turn power on PS w/ an inline fuse.  Is the SW-06 IEC Switch some type of safety feature ?
Sorry for all the ques, but Ive gotten this far w/out burning anything up. ;D
« Last Edit: January 03, 2015, 10:10:03 PM by knucklbustr »
