Hello Guest it is November 27, 2026, 01:11:25 PM
Author Topic: Estop w/ 2 Ports  (Read 23762 times)
Re: Estop w/ 2 Ports
« Reply #10 on: January 03, 2015, 11:20:05 PM »
The switch on the enable line allows you to de-energise the stepper motors, allowing you to adjust the axis position by hand. I find it useful for setting the z-axis to the top of the work surface.
Output #6 is switching mains power to an outlet socket. You can use it to turn on a vacuum system or flood coolant pump, etc.  The active supply to this should really go via the EStop switch as well. I need to update that on the diagram.
There is nothing special about the IEC switch block, other than it has a switch, fuse holder and IEC lead socket in a neat package. What you are using is fine.
http://www.homanndesigns.com/store/index.php?main_page=product_info&cPath=29&products_id=86
Cheers,
Peter
Homann Designs
Offline knucklbustr
  •  9 9
  • Philly Burbs
« Reply #11 on: January 08, 2015, 09:30:32 AM »
Should limit switches be tied in w/ a power supply ?
If I understand correctly, the above posted design has limit switches thru the Geck540.
If a switch is tripped, is sent thru the Gecko540 causing a stop to axis pin 1-4. Reset thru Mach3.
Which opens another ques. If an axis has hit a limit, how can you move it off the limit if there is an estop ?
I havnt tried this yet.
I have decided to use the Neg 48v PS thru my estop.
Im also tying in the Neg from Z-driver w/ estop.
Still trying to figure using Z limits in conjunction w/ Gecko540
From my initial post, Z is handled by a separate BOB and driver on port 2. Limits are NO, not NC .
« Last Edit: January 08, 2015, 09:32:59 AM by knucklbustr »
The right hand is always beating up my left hand.
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #12 on: January 08, 2015, 09:57:13 AM »
Very bad idea!!! You want to cut off the AC input to the power supply NOT the DC form power supply to the stepper drive.
Well, it depends :) If you have a small machine and running it into a hard stop at the end of the axis travel won't break things then using a limit that is just SW controlled is OK. On large machines the limits are often tied to a system that will trip an EStop, and brake the axis. On an industrial machine there are often regulations that specify how this must be handled.
Happy machining , Jeff Birt
Offline knucklbustr
  •  9 9
  • Philly Burbs
« Reply #13 on: January 08, 2015, 10:30:52 AM »
Why is it a bad way using 48v PS ?
Im concerned running a 120v neutral line around my mill.
Probably would have to use 12ga solid. Then enclose in a protective conduit of some type.
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #14 on: January 08, 2015, 10:53:14 AM »
I think we are talking about different things. Your EStop should cut the AC feeding the power supply, this does not mean you run 120V to your EStop unless it is a small machine and you can mount the EStop in the same cabinet as the rest of your electronics. If your EStop is mounted remotely then your EStop circuit should trigger a contactor/safety relay that energized the power supply.
it is not a good idea to try and cut the DC power between the power supply and Stepper drive, this can lead to a blown up stepper drive.
Offline knucklbustr
  •  9 9
  • Philly Burbs
« Reply #15 on: January 08, 2015, 08:18:10 PM »
Where do I get a power source for this relay ?
I have a SSR-25-DA. Input 3-32VDC
