Hello Guest it is October 21, 2026, 10:18:58 AM
Author Topic: Output issue  (Read 12358 times)
Output issue
« on: April 04, 2007, 02:47:01 PM »
I have outputs on port #1 on pins #1, 2, 9, 14, 16, & 17.  They are all set up active high except #2 which is reverse polarity (active low).
I have # 14, 16, & 17 set up with touchscreen buttons - they work just fine.
I have #1, 2, & 9 set up as enable switches, so each should toggle when I hit the reset button.  However, #1 won't go high - anybody have a clue why that might be?
Re: Output issue
« Reply #1 on: April 04, 2007, 02:59:42 PM »
I'm not certain but this may have something to do with it. Bottom left corner of general config.
Re: Output issue
« Reply #2 on: April 04, 2007, 08:48:31 PM »
Check with a meter at the port.. that is strange to have all others work and one not.
www.newfangledsolutions.com
www.machsupport.com
Re: Output issue
« Reply #3 on: April 05, 2007, 08:41:53 AM »
I made a breakout circuit board similar to those sold by others on this site, but taylored to our needs.  I can turn on the outputs, and easily measure the changes on the exposed pins - in this case, the lead end of a resistor.
All work but #1.
Re: Output issue
« Reply #4 on: April 06, 2007, 12:59:46 PM »
Sounds to me like you have a prots and pins settings that are not right OR you have a bad pin :(
www.machsupport.com
Re: Output issue
« Reply #5 on: April 06, 2007, 01:59:08 PM »
As always - the last thing you'd expect.
The cable had a pin that was present, but broken off internally.
