Hello Guest it is November 22, 2026, 10:14:50 PM
Author Topic: Upgraded to Mach3 1.84.001... no movement!  (Read 17252 times)
manine
« on: March 01, 2006, 09:58:07 AM »
Hello all
I just upgraded Mach3 from 1.84.000 to 1.84.001 in hopes of getting the "cut rectangle" Newfangled wizard to work right. Now my motors don't move! All the settings seem to be intact, Jog mode is on.
-Matt
Re: Upgraded to Mach3 1.84.001... no movement!
« Reply #1 on: March 01, 2006, 03:27:16 PM »
Check the jog mode :)
www.newfangledsolutions.com
www.machsupport.com
manine
« Reply #2 on: March 03, 2006, 09:09:03 AM »
Jog mode is on, doesn't work in step or cont
The coordinates move on the screen... not on the machine.
Mach 2 works fine, I finished building my little project with New Fangled wizards. I have to load the code into Mach 2- the problem I had with the rectangle wizard disappeared when I cut with Mach2!
-Matt
« Reply #3 on: March 03, 2006, 04:53:08 PM »
Sound like there is a ports and pins config problem...
www.machsupport.com
