Hello Guest it is November 11, 2026, 11:22:03 PM
Author Topic: Losing zero reference while cutting  (Read 57792 times)
Offline $cott
  •  36 36
« on: December 24, 2014, 08:45:00 AM »
Can some one tell me why i keep losing zero reference while cutting.  I zero my system then while cutting a various pionts i lose zero and Mach3 starts cutting in the wrong place.  I just set up Mach3 on a small CNC router have i set something up wrong?
Scott
  •  9,377 9,377
Re: Losing zero reference while cutting
« Reply #1 on: December 26, 2014, 04:04:26 AM »
You say "cutting in the wrong place" - could you be more specific, where abouts is it cutting in the wrong place ??
A picture of the problem would be good.
Offline $cott
  •  36 36
« Reply #2 on: December 26, 2014, 09:33:16 PM »
While cutting at what seems to be random times i lose reference to my zero location and my CNC cuts in totally the wrong place.  When i stop the unit and do a GOTO zero command it returns to totally the wrong place.  It does this at random times while i cut, and is just so frustrating because i don't know where to look for a solution.
Scott
  •  9,377 9,377
« Reply #3 on: December 27, 2014, 01:00:55 AM »
You are still not giving me much information to go on.  :-\
Try reducing your Velocity and Acceleration settings (in Motor Tuning) by 50% then save the changes for each axis. See if this solves the problem.
Offline $cott
  •  36 36
« Reply #4 on: December 27, 2014, 11:02:04 AM »
I already tried that, i though that was also the problem but it still does the same thing.  I will reduce it some more and see if it helps.
Scott
Offline $cott
  •  36 36
« Reply #5 on: December 27, 2014, 11:03:31 AM »
Tweakie ... what information would be helpful for you to see so i can get it to you?
Scott
  •  9,377 9,377
« Reply #6 on: December 27, 2014, 11:15:47 AM »
Hi Scott,
I am sorry that did not resolve the problem. A few questions for you...
Which axis is going wrong and in which direction ?
How much is it wrong (approx.) ?
Do the Mach3 DRO's show the correct position ?
Does the machine make any unusual noise when the error occurs ?
Have you thoroughly checked all mechanical parts, in particular for loose couplings / grub screws etc. ?
Posting a picture of the work, showing the problem, would be helpful (use Additional Options)
Offline $cott
  •  36 36
« Reply #7 on: December 27, 2014, 11:40:32 AM »
Which axis is going wrong and in which direction ? Ans: both x and y forsure, but z i did not pay that much detail to.[/color]
How much is it wrong (approx.) ?  Ans: For example i was cutting a profile that is 7 ich long when it went bad i lost 4 inch in x and 2 inches in y.
Do the Mach3 DRO's show the correct position ?  Ans: The DRO i belive are showing up properly but zer in x, y is shifted.  Note z might be also but i deed not note it.
Does the machine make any unusual noise when the error occurs ? No unusual noice
Have you thoroughly checked all mechanical parts, in particular for loose couplings / grub screws etc. ?  Ans: This i did not do, I did however manualy turn each axis by hand full strok to see if i had any binding and did not notice any on any axis.
Posting a picture of the work, showing the problem, would be helpful (use Additional Options)  Ans: I will do this as soon as i get to office.  Right now i beeter keep my wife happy so i wont get this this till Monday!
Note:  This mill i have had for 5 years its a small panther-210 and has work flawlessly for all this time.  I did however switch it to a new computer that was a 64 bit machine and i loaded 32 bit version of windows 7 on it.  Would this have any issues that you would know of?  Is it possible that i have a bad parallel port on this machine?  The CPU is a Dell
Scott
Scott
  •  9,377 9,377
« Reply #8 on: December 28, 2014, 12:45:37 AM »
Hi Scott,
From what you describe it sounds like the problem may all be down to the PC.
Run the DriverTest.exe (Mach3 folder) and see what results you get.
Offline $cott
  •  36 36
« Reply #9 on: December 29, 2014, 09:30:50 AM »
I will do that this morning first thing  ... FYI I want to thank you for being so helpful and patience!
Scott
