Hello Guest it is August 07, 2026, 08:47:42 AM
Author Topic: Needing help with screens  (Read 57736 times)
0 Members and 6 Guests are viewing this topic.
Offline dude1
  •  1,253 1,253
« Reply #20 on: December 03, 2014, 08:31:40 PM »
yer should of put in what I have tried
below works with out mc.mcAxisSetPos(inst, 0, 0.000) or mc.mcMotorSetHomePos(inst,0,0); -- inst, 0= X axis , 0 = set to home anything else is counts per unit
if I add one or the other of the above codes it stops the output turning off and the axis`s don't go to zero.
I put them in after gcode execute
--Laser Zero
--Get the instance of the controller
local inst= mc.mcGetInstance();
mc.mcCntlGcodeExecute(inst, "G1 X10 Y10 F500");--run some g-code
--Get the out5 handle
local out5= mc.mcSignalGetHandle(inst, mc.OSIG_OUTPUT5);
--Output TOGGLE
 local outstate = mc.mcSignalGetState(out5);
 if (outstate == 1) then
   mc.mcSignalSetState(out5, false);
 else
   mc.mcSignalSetState(out5, true);
 end
« Reply #21 on: December 03, 2014, 08:39:35 PM »
It worked here zeroed out the XY after the Gcode move
mc.mcAxisSetPos(inst, 1, 0.000)
Offline dude1
  •  1,253 1,253
« Reply #22 on: December 03, 2014, 08:54:41 PM »
did you try it like this did it turn your output 5 on
Code: [Select]
--Laser Zero
mc.mcAxisSetPos(inst, 0, 0.000);
mc.mcAxisSetPos(inst, 1, 0.000);
--Output TOGGLE
 else
 end
Re: Needing help with screens
« Reply #23 on: December 03, 2014, 09:26:13 PM »
Have you setup output5 in config?
« Reply #24 on: December 03, 2014, 09:37:14 PM »
I cannot set up output 5 in the DEMO. BUT I did setup output3 and ran this code and it turned ON the output3.
 --Laser Zero
mc.mcCntlGcodeExecute(inst, "G1 X10 Y10 F50");--run some g-code
--Get the out3 handle
local out3= mc.mcSignalGetHandle(inst, mc.OSIG_OUTPUT3);
--Output TOGGLE
 local outstate = mc.mcSignalGetState(out3);
   mc.mcSignalSetState(out3, false);
 else
   mc.mcSignalSetState(out3, true);
 end
Offline dude1
  •  1,253 1,253
« Reply #25 on: December 03, 2014, 09:45:31 PM »
I am get output 5 on and off its just not zeroing x an y after move
« Last Edit: December 03, 2014, 09:53:54 PM by daniellyall »
« Reply #26 on: December 03, 2014, 09:47:03 PM »
Now the real kicker is IF I load the code and run it once it runs ok. IF I then run it a 2nd time it runs the Gcode twice in a row(0 -10/0, 0-20/0, CRASH) . IF I run it the third time it locks up mach4.
Probably a SIM() problem, (;-) TP
« Reply #27 on: December 03, 2014, 09:48:28 PM »
(;-) Its not doing ? what?
Offline dude1
  •  1,253 1,253
« Reply #28 on: December 03, 2014, 09:55:12 PM »
I will try in virtualmotion
« Reply #29 on: December 03, 2014, 10:16:37 PM »
See if this bit works as expected. If it does, you can then build on it. I would work on one bit at the time.
Code: [Select]
local inst = mc.mcGetInstance();
wx.wxMilliSleep(10);
mcState = mc.mcCntlGetState(inst);
while (mcState ~= mc.MC_STATE_IDLE) do
end
mc.mcAxisSetPos(inst, 2, 0.000)
