Hello Guest it is October 23, 2026, 01:11:17 PM
Author Topic: Needing help with screens  (Read 59551 times)
« Reply #10 on: December 03, 2014, 09:48:19 AM »
Craig, sorry I mixed you up with someone else.
JUST pickin on ya , (;-) TP
« Reply #11 on: December 03, 2014, 10:32:49 AM »
IF you want a bird's eye view of all the associated Code in a screenset do as Craig suggested and goto the screen XML and view . It has ALL of the screen code layed out for you to see. AND it is in screen order.
Next will be to get brave and get you a pair of sissors and a bottle of glue and get to cutting and pasting. That IS next on the list as I cannot figure out a way in the screen editor to move MAJOR things around.
Offline dude1
  •  1,253 1,253
« Reply #12 on: December 03, 2014, 12:07:33 PM »
that be madman secretary
I am going to try and do the 2 codes I wont today
Offline dude1
  •  1,253 1,253
« Reply #13 on: December 03, 2014, 04:39:06 PM »
does anyone now the code to zero an axis after its moved to a position cant find any code for doing it
« Reply #14 on: December 03, 2014, 05:10:40 PM »
I think this may be what your looking for Daniell.
mc.mcAxisSetPos(inst, 0, 0.000)
« Reply #15 on: December 03, 2014, 05:24:31 PM »
VP  ??? I cannot even get a screen button to work right  ;D
Now for those Mcodes and param calls . THAT is the cats meow IT seems that there are 2 var sets associated withe G65#vars. Var_A and #1. The Var_A populates the #1 so  the macro Parm call  use it only querries the Var_A side and does NOT effect the #1.  At least it seems that way here. I can't test with G65 here so it is just a guess as it does not show up in the Var monitor.
Does anyone know how many ways you can blow up a ScreenXML (;-) and still counting. Interresting those XML thingys
« Reply #16 on: December 03, 2014, 06:14:23 PM »
Well I can move a control group AND it shows the new location in the TREE, BUT it will NOT display in the editor OR in Mach4. Restart Mach4 as well still no show.
Offline dude1
  •  1,253 1,253
« Reply #17 on: December 03, 2014, 07:03:09 PM »
deep breaths
Offline dude1
  •  1,253 1,253
« Reply #18 on: December 03, 2014, 07:17:45 PM »
thanks gents I must be missing something cant get the axis`s to zero out.
this is what I have so far.
This works
Code: [Select]
--Laser Zero
--Get the instance of the controller
local inst= mc.mcGetInstance();
mc.mcCntlGcodeExecute(inst, "G1 X10 Y10 F500");--run some g-code
--Get the out5 handle
local out5= mc.mcSignalGetHandle(inst, mc.OSIG_OUTPUT5);
--Output TOGGLE
 local outstate = mc.mcSignalGetState(out5);
 if (outstate == 1) then
   mc.mcSignalSetState(out5, false);
 else
   mc.mcSignalSetState(out5, true);
 end
« Reply #19 on: December 03, 2014, 07:49:57 PM »
Daniel I do not see any code to zero the axis . Am I missing something
