Hello Guest it is October 23, 2026, 10:47:37 PM
Author Topic: Ethernet Smooth Stepper.  (Read 35661 times)
  •  9,374 9,374
« on: December 03, 2014, 02:13:43 AM »
Just a heads-up for those using the Ethernet Smooth Stepper.
The beta version of the ESS Mach4 plugin has now been released http://warp9td.com/index.php/sw
A huge thanks goes out to Greg for all his continuing hard work with this plugin, which is available free of charge, and I sincerely hope that increased sales of the ESS more than pay him for all the time he has dedicated to this product.
« Last Edit: December 03, 2014, 02:32:33 AM by Tweakie.CNC »
Re: Ethernet Smooth Stepper.
« Reply #1 on: December 03, 2014, 06:48:34 AM »
Thank You Greg
  •  9,374 9,374
« Reply #2 on: December 03, 2014, 06:57:21 AM »
Could have not been put better my friend.
« Reply #3 on: December 03, 2014, 10:19:41 AM »
Thank you both for your kind words!  Your support of the product means a lot to everyone.  I'm really happy to be part of the Mach4 revolution.
Greg
« Reply #4 on: December 03, 2014, 10:25:30 AM »
Hey Greg!
yes, thanks, and just have to ask, any eta on the MPG stuff?
Scott
« Reply #5 on: December 03, 2014, 10:38:29 AM »
be cautious before you load this mach4 driver. It changed the bootloader signature on the ESS and now the Mach3 driver will not load. So until there is a re-compiled Mach3 driver which I assume Greg will create really soon, I wouldn't be even attempting to use the driver.
Colten Edwards
www.lasernthings.ca
« Reply #6 on: December 03, 2014, 10:53:43 AM »
I'm really sorry to hear about that happening.  It is the first time I've ever heard of that happening.  I really don't think it is the plugin that did it.  I think it is just coincidence.  It uses the same loading mechanism as Mach3.  The signature is a CRC, and the bootloader is evidently corrupt.  Can you run Mach3?  I'll get this fixed for you.  Please contact me at support@warp9td.com if the problem persists.
Greg
« Reply #7 on: December 03, 2014, 10:55:27 AM »
Hi Scott.  MPGs are really high on the list.  I need to get the outputs working first.  As soon as that is resolved I will get MPGs added.  And then spindle.
Greg
« Reply #8 on: December 15, 2014, 01:25:34 AM »
Hi All
I hope someone can help.
I heve set up Mach 4 and ESS the same as mach 3 but when I jog X Y or Z the dro's move but the motors don't. When I jog A the DRO'S move and the motors move.
I am usung Win 7 32 bit with a C32 BOB my system works fine in Mach3.
Bob
« Reply #9 on: December 16, 2014, 12:30:40 AM »
Hi All
Yuo are not going to beleive this but I just switched everything on and Hey Presto it all works
Thanks Bob
