Hello Guest it is November 01, 2026, 10:12:21 AM
Author Topic: lazycam  (Read 11118 times)
lazycam
« on: April 02, 2007, 03:14:29 PM »
I have just downloaded lazycam for the first time.  I am not a teckie but I can still figure most things out.  What I can't figure is how do you machine a face in milling leaving an island in the centre.  The only thing I can do is profile and only if I only take one cut.  If i want to take more than 1 cut do I have to put in extra lines around the profile.
Any help wopuld be appreciated
Doug
Re: lazycam
« Reply #1 on: April 02, 2007, 07:56:56 PM »
Hi, Houseboater:
If I  read your questin correctly; There are two ways to leave an island.  Easiest is if you have paid for the Pro-version of LazyCam.  Then all you have to do is add an offset and key in different values for depth of cuts.  If you want a lot of space between your outer perimeter and the island, you could then select the pocketing function.
The other way, and this is the way I have done it before LazyPro. is to draw your dxf with an offset and then select different chains.  It is more difficult to leave a larger area using this metiod.
Hope I understood the question, and that this helps.
Bob @ BobsShop- Back to cutting and polsihing.
judah
Re: lazycam
« Reply #2 on: May 30, 2007, 08:57:59 PM »
is lazy cam pro on sell now and is the turn portion working?
Re: lazycam
« Reply #3 on: June 01, 2007, 04:18:58 PM »
Turn has not been worked on but we hope to have time to work on it next week.
Thank you
Brian
www.newfangledsolutions.com
www.machsupport.com
