Hello Guest it is November 04, 2026, 11:11:58 AM
Author Topic: CSMIO/IP-S vs DELTA ASDA-B2  (Read 123334 times)
Offline Arman
  •  20 20
Re: CSMIO/IP-S vs DELTA ASDA-B2
« Reply #20 on: November 21, 2014, 02:12:14 AM »
Here is the complete macro from CS Lab
Code: [Select]
' CS-Lab s.c.
' Toolchanger VB macro (MILL - Flat ATC with toolholders on the work table)
' v1.3
' Digital outputs CONFIG
Const OUT_OPENCOLLET = 10 ' open collet CSMIO output
Const OUT_CLEANCONE = 11 ' cone cleaning CSMIO output
Const OUT_CURTAIN = 12 ' raise curtain CSMIO output
' Digital inputs CONFIG
Const IN_COLLETCLOSED = 20 ' collet locked sensor CSMIO input
Const IN_COLLETOPENED = 21 ' collet open sensor CSMIO input
Const IN_TOOLINSIDE = 22 ' tool locked sensor CSMIO input
' variables declaration - don't modify
Dim Z_TOOLGET, Z_LIFT, Z_SAFE, X_FORSLIDE, X_LOCK, Y_BASE, Y_TOOLOFFSET, TOOLCOUNT
Dim ToolNew, ToolOld
Dim SoftLimitsState As Boolean
' CONFIG data
Y_TOOLOFFSET = 170.00 ' distance between tools
Y_BASE = 42.93 ' Y position of first tool
Z_TOOLGET = -311.3 ' Z position (abs) of tool get/relase
Z_SAFE = -220 ' Safe Z for safe moving above tool holders
Z_LIFT = 10 ' rise distance for cone cleaning
X_FORSLIDE = -50 ' X position before slide tool into the holder
X_LOCK = -100 ' X position for lock tool into the holder
TOOLCOUNT = 6 ' Max. tool number
  ' Macro start
   SetUserLED(1001, 1) ' UserLED 1001 - private info, toolchange is in progress
' Get the current tool # and new tool #
ToolOld = GetCurrentTool()
ToolNew = GetSelectedTool()
' save softlimits state
If(GetOEMLED(23)) Then
SoftLimitsState = true
Else
SoftLimitsState = false
End If
' turn off softlimits - toolholders can be outside normal work area
SoftLimitsOff
' raise the curtain
Call SetCsmioOut (OUT_CURTAIN, true)
' check are the axes referenced
If GetOEMLed(807) Then
SetCurrentTool( ToolOld )
SetUserLED(1001, 0)
DoOEMButton(1003)
DoOEMButton(1002)
Sleep(150)
Message( "Machine is not referenced" )
Sleep(150)
' restore softlimit
SetSoftLimits(SoftLimitsState)
' curtain down
Call SetCsmioOut (OUT_CURTAIN, false)
End
End If
If GetOEMLed(808) Then
SetUserLED(1001, 0)
DoOEMButton(1003)
DoOEMButton(1002)
Sleep(150)
Sleep(150)
' restore softlimit
' curtain down
End
End If
If GetOEMLed(809) Then
SetUserLED(1001, 0)
DoOEMButton(1003)
DoOEMButton(1002)
Sleep(150)
Sleep(150)
' restore softlimit
' curtain down
End
End If
If GetOEMLed(11) Then
SetUserLED(1001, 0)
DoOEMButton(1003)
DoOEMButton(1002)
Sleep(150)
Message( "Spidnle is running. Toolchange failed." )
Sleep(150)
' restore softlimit
' curtain down
End
End If
' Spindle must be turned off for toolchange
If (ToolNew = ToolOld) Then
If (IsToolInside()) Then
SetUserLED(1001, 0)
Sleep(150)
Message("Tool is already in spindle.")
Sleep(150)
' restore softlimit
' curtain down
End
End If
End If
' New tool # must be <= TOOLCOUNT
If (ToolNew > TOOLCOUNT) Then
SetUserLED(1001, 0)
DoOEMButton(1003)
DoOEMButton(1002)
Sleep(150)
Message("There is no such a tool.")
Sleep(150)
' restore softlimit
' curtain down
End
End If
Code("G0G53 Z0.0") ' Z up to machine '0'
WaitForMove
' if current tool > 0 put it first into the holder
If (ToolOld > 0) Then
' if there is no tool in spindle, skip this part
' move to the toolholder
Code("G0G53 X"& X_FORSLIDE &" Y" & (Y_BASE + (Y_TOOLOFFSET * (ToolOld-1))))
WaitForMove
Code("G0G53 Z" & Z_TOOLGET)
WaitForMove
Code("G0G53 X" & X_LOCK)
WaitForMove
ColletOpen
CleanConeOn
Sleep(1000)
' is collet opened?
If (Not IsColletOpened()) Then
ColletClose
CleanConeOff
Sleep(1000)
Code("G0G53 X"& X_FORSLIDE)
WaitForMove
Code("G0G53 Z0")
Code("G0G53 X0Y0")
WaitForMove
SetUserLED(1001, 0)
DoOEMButton(1021)
DoOEMButton(1002)
Sleep(150)
Message("Can't open collet! Toolchange failed.")
Sleep(150)
' restore softlimit
' curtain down
End
End If
Code("G0G53 Z" & Z_SAFE)
WaitForMove
CleanConeOff
ColletClose
End If
End If
' If newtool = 0, there is no need to get new tool
If (ToolNew = 0) Then
Code("G0G53 Z0")
WaitForMove
Code("G0G53 X0Y0")
WaitForMove
SetCurrentTool( ToolNew )
Message("Tool loaded : " & ToolNew)
Code("G43T" & ToolNew) ' G43 to sync tool length in system
Code("G43H" & ToolNew) ' G43 to sync tool length in system
WaitForMove
SetUserLED(1001, 0)
' restore softlimits
' curtain down
End
End If
' Is there no tool in the spindle?
Code("G0G53 Z0")
Code("G0G53 X0Y0")
WaitForMove
SetUserLED(1001, 0)
WaitForMove
DoOEMButton(1021)
DoOEMButton(1002)
Sleep(150)
Message("Can't get new tool, because other tool is already in spindle!")
Sleep(150)
' curtain down
End
End If
' move to the new tool position
Code("G0G53 X" & X_LOCK &" Y" & (Y_BASE + (Y_TOOLOFFSET * (ToolNew-1))))
WaitForMove
ColletOpen
Sleep(1000)
' check is the collet opened
If (Not IsColletOpened) Then
CleanConeOff
ColletClose
Sleep(1000)
WaitForMove
Code("G0G53 Z0")
Code("G0G53 X0Y0")
WaitForMove
SetCurrentTool( 0 )
SetUserLED(1001, 0)
DoOEMButton(1021)
DoOEMButton(1002)
Sleep(150)
Message("Can't open collet! Toolchange failed!")
Sleep(150)
' curtain down
End
End If
' cone cleaning
CleanConeOn
Code("G0G53 Z" & (Z_TOOLGET + Z_LIFT))
Code("G1G53 Z" & Z_TOOLGET & " F3000")
Code("G1G53 Z" & (Z_TOOLGET + Z_LIFT) & " F3000")
Code("G1G53 Z" & Z_TOOLGET & " F1500")
WaitForMove
' colled close
CleanConeOff
Sleep(500)
ColletClose
Sleep(1000)
' check is tool locked?
If (Not IsToolInside()) Then
WaitForMove
Code("G0G53 Z0")
Code("G0G53 X0Y0")
WaitForMove
SetCurrentTool( 0 )
SetUserLED(1001, 0)
DoOEMButton(1021)
DoOEMButton(1002)
Sleep(150)
Message("Toolchange failed. Tool should be locked!")
Sleep(150)
' curtain down
End
End If
' slide out from toolholder position
Code("G0G53 X" & X_FORSLIDE)
WaitForMove
Code("G0G53 Z0")
WaitForMove
' Go to absolute 0,0
Code("G0G53 X0 Y0")
WaitForMove
Message("Tool Loaded: " & ToolNew)
WaitForMove
SetUserLED(1001, 0)
' restore softlimit
' curtain down
End
Public Function IsToolInside () As Boolean
If(GetCsmioIn(IN_TOOLINSIDE)) Then
IsToolInside = true
Else
IsToolInside = false
End If
Exit Function
End Function
Public Function IsColletOpened () As Boolean
If(GetCsmioIn(IN_COLLETOPENED)) Then
IsColletOpened = true
Else
IsColletOpened = false
End If
Exit Function
End Function
Public Function IsColletClosed () As Boolean
If(GetCsmioIn(IN_COLLETCLOSED)) Then
IsColletClosed = true
Else
IsColletClosed = false
End If
Exit Function
End Function
Sub ColletClose ()
Call SetCsmioOut(OUT_OPENCOLLET, false)
End Sub
Sub ColletOpen ()
Call SetCsmioOut(OUT_OPENCOLLET, true)
End Sub
Sub CleanConeOn ()
Call SetCsmioOut(OUT_CLEANCONE, true)
End Sub
Sub CleanConeOff ()
Call SetCsmioOut(OUT_CLEANCONE, false)
End Sub
Sub SoftLimitsOff ()
DoOEMButton(1029)
End If
End Sub
Sub SetSoftLimits (state As Boolean)
If(state) Then
If(GetOEMLED(23) = 0) Then
DoOEMButton(1029)
End If
Else
DoOEMButton(1029)
End If
End If
End Sub
Sub WaitForMove ()
While IsMoving()
Sleep(15)
Wend
End Sub
Public Function GetCsmioIn (n As Integer) As Boolean
Dim reg As Integer
If(n < 16) Then
reg = 90
Else
reg = 91
n = n - 16
End If
If(GetInBit(reg, n)) Then
GetCsmioIn = true
Else
GetCsmioIn = false
End If
Exit Function
End Function
Public Sub SetCsmioOut (ByVal n As Integer, ByVal state As Boolean)
If(state) Then
SetOutBit(90, n)
Else
ResetOutBit(90, n)
End If
End Sub
« Last Edit: November 21, 2014, 05:53:02 AM by Ya-Nvr-No »
Offline Arman
  •  20 20
« Reply #21 on: November 21, 2014, 02:21:00 AM »
Offline TPS
  •  2,627 2,627
« Reply #22 on: November 21, 2014, 06:34:55 AM »
Hi Arman,
here the modified macro.
modifications:
-no curtain
-no tool present switch
all modifications marked with TPS
Code: [Select]
' CS-Lab s.c.
' v1.3
' modified  TPS 21.11.2014
'TPS no curtail present
'Const OUT_CURTAIN     = 12 ' raise curtain CSMIO output
'TPS no tool inside sensor present
'Const IN_TOOLINSIDE     = 22 ' tool locked sensor CSMIO input
' CONFIG data
  ' Macro start
Else
End If
SoftLimitsOff
'TPS no curtain
    ' raise the curtain
' Call SetCsmioOut (OUT_CURTAIN, true)
SetUserLED(1001, 0)
DoOEMButton(1003)
DoOEMButton(1002)
Sleep(150)
Sleep(150)
' restore softlimit
'TPS no curtain
' curtain down
' Call SetCsmioOut (OUT_CURTAIN, false)
End
End If
SetUserLED(1001, 0)
DoOEMButton(1003)
DoOEMButton(1002)
Sleep(150)
Sleep(150)
' restore softlimit
'TPS no curtain
' curtain down
End
End If
SetUserLED(1001, 0)
DoOEMButton(1003)
DoOEMButton(1002)
Sleep(150)
Sleep(150)
' restore softlimit
'TPS no curtain
' curtain down
End
End If
SetUserLED(1001, 0)
DoOEMButton(1003)
DoOEMButton(1002)
Sleep(150)
Message( "Spindle is running. Toolchange failed." )
Sleep(150)
' restore softlimit
'TPS no curtain
' curtain down
End
End If
'TPS no tool present switch
'    If (IsToolInside()) Then
SetUserLED(1001, 0)
Sleep(150)
Sleep(150)
' restore softlimit
' curtain down
End
' End If
End If
SetUserLED(1001, 0)
DoOEMButton(1003)
DoOEMButton(1002)
Sleep(150)
Sleep(150)
' restore softlimit
'TPS no curtain
' curtain down
End
End If
WaitForMove
WaitForMove
WaitForMove
WaitForMove
ColletOpen
CleanConeOn
Sleep(1000)
' is collet opened?
ColletClose
CleanConeOff
Sleep(1000)
WaitForMove
Code("G0G53 Z0")
Code("G0G53 X0Y0")
WaitForMove
SetUserLED(1001, 0)
DoOEMButton(1021)
DoOEMButton(1002)
Sleep(150)
Sleep(150)
' restore softlimit
'TPS no curtain
' curtain down
End
End If
WaitForMove
CleanConeOff
ColletClose
' End If
End If
Code("G0G53 Z0")
WaitForMove
Code("G0G53 X0Y0")
WaitForMove
WaitForMove
SetUserLED(1001, 0)
'TPS no curtain
' curtain down
End
End If
' Code("G0G53 Z0")
' Code("G0G53 X0Y0")
' WaitForMove
' SetCurrentTool( ToolOld )
' SetUserLED(1001, 0)
' WaitForMove
' DoOEMButton(1021)
' DoOEMButton(1002)
' Sleep(150)
' Message("Can't get new tool, because other tool is already in spindle!")
' Sleep(150)
' SetSoftLimits(SoftLimitsState)
' curtain down
' End
' End If
WaitForMove
ColletOpen
Sleep(1000)
CleanConeOff
ColletClose
Sleep(1000)
WaitForMove
Code("G0G53 Z0")
Code("G0G53 X0Y0")
WaitForMove
SetCurrentTool( 0 )
SetUserLED(1001, 0)
DoOEMButton(1021)
DoOEMButton(1002)
Sleep(150)
Sleep(150)
'TPS no curtain
' curtain down
End
End If
' cone cleaning
CleanConeOn
WaitForMove
' colled close
CleanConeOff
Sleep(500)
ColletClose
Sleep(1000)
'TPS no tool presnt switch
' If (Not IsToolInside()) Then
' Code("G0G53 X"& X_FORSLIDE)
' WaitForMove
' Code("G0G53 Z0")
' WaitForMove
' SetCurrentTool( 0 )
' DoOEMButton(1021)
' DoOEMButton(1002)
' Sleep(150)
' Message("Toolchange failed. Tool should be locked!")
' Sleep(150)
' curtain down
' End
' End If
WaitForMove
Code("G0G53 Z0")
WaitForMove
Code("G0G53 X0 Y0")
WaitForMove
WaitForMove
SetUserLED(1001, 0)
' restore softlimit
'TPS no curtain
' curtain down
End
IsToolInside = true
Else
End If
Exit Function
End Function
Else
End If
Exit Function
End Function
Else
End If
Exit Function
End Function
Sub ColletClose ()
End Sub
Sub ColletOpen ()
End Sub
Sub CleanConeOn ()
End Sub
Sub CleanConeOff ()
End Sub
DoOEMButton(1029)
End If
End Sub
If(state) Then
DoOEMButton(1029)
End If
Else
DoOEMButton(1029)
End If
End If
End Sub
Sub WaitForMove ()
While IsMoving()
Sleep(15)
Wend
End Sub
Dim reg As Integer
If(n < 16) Then
reg = 90
Else
reg = 91
n = n - 16
End If
GetCsmioIn = true
Else
GetCsmioIn = false
End If
Exit Function
End Function
If(state) Then
SetOutBit(90, n)
Else
ResetOutBit(90, n)
End If
End Sub
Thomas
Offline Arman
  •  20 20
« Reply #23 on: November 21, 2014, 07:03:53 AM »
Thanks again Thomas. Anyway I'm just wondering how bad it is for my case? Mayby I have a need to add sensors in toolholder forks?
Offline TPS
  •  2,627 2,627
« Reply #24 on: November 21, 2014, 07:14:57 AM »
Hi Arman,
in my machine i have a tool present switch for every toolholder and in the spindle,
it depends on how "save" and "idiotproved" the system should run.
Thomas
Offline TPS
  •  2,627 2,627
« Reply #25 on: December 11, 2014, 01:49:11 AM »
Hi Arman,
any new photos of the progress of your machine ?
Thomas
Offline Arman
  •  20 20
« Reply #26 on: December 11, 2014, 10:03:57 AM »
Hello Thomas. I am done with electronics and rotary head. Works fine. Just today received pneumatic cylinders and now working on Z axis counterweight, also ATC pneumatics. Tomorrow will take some pistures for you.
Offline Arman
  •  20 20
« Reply #27 on: December 15, 2014, 03:46:18 AM »
Hello people. My internet was awfull... Could not upload video before. Anyway, here is firs test moving of my router. http://youtu.be/nttAjtHWcKQ
« Reply #28 on: December 15, 2014, 05:44:33 AM »
Holly snapping duck *********! That is bloody awesome. Is that the 929 long spindle. I have the 915 short.
Alan
Offline Arman
  •  20 20
« Reply #29 on: December 15, 2014, 07:45:21 AM »
Yes Alan, this is 929 long nose, but not HSD, just china copy:))
