Hello
Guest
it is
November 04, 2026, 01:13:07 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
CS-Lab
CSMIO/IP-S vs DELTA ASDA-B2
« previous
next »
Print
Pages:
1
2
3
4
Go Down
Author
Topic: CSMIO/IP-S vs DELTA ASDA-B2 (Read 123356 times)
Arman
20
on:
November 14, 2014, 03:13:14 AM »
Hello to everyone. First of all sorry for my English, I am from Armenia...
I need some help. I have CSMIO/IP-S v2 and servos from Delta. I wired all using the sample scetch from CS-Lab site. The problem is I can not run the servos from Mach3. Can anybody help me with proper settings of Mach3 and CSMIO/IP plugin to make servos to run. Thanks in advance.
TPS
2,627
Re: CSMIO/IP-S vs DELTA ASDA-B2
Reply #1 on:
November 14, 2014, 05:11:55 AM »
have you set in Output aeria Enable1 to port 10 pin 0 ? That is your enable for the drives.
are your positions chaning in mach3 if you try to move in manual ?
are you able to clear the reset button ?
Thomas
Arman
20
Reply #2 on:
November 14, 2014, 05:25:08 AM »
Hello Thomas. Thanks for reply. Here is what I set for X axis.
Mach3
Motor Outputs -> X axis Enabled
Input Signals -> Estop Enabled port10 pin2
Output Signals -> Enable1 port10 pin0
In Plugin -> Spetial function tab -> Misc IO
Servodrive Reset Enabled -> Output 2
When I press Reset in Mach3, servo goes to hold, and thats OK. When manual jog - mach3 showes move in X, but servo shaft don't rotating
TPS
2,627
Reply #3 on:
November 14, 2014, 05:36:20 AM »
drives are set to position control mode and right signals for pulse an dir ?
i am not so familiar with the delta drives, never had one.
Thomas
Arman
20
Reply #4 on:
November 14, 2014, 05:46:31 AM »
Yes, drives are set to position control by default...
TPS
2,627
Reply #5 on:
November 14, 2014, 05:52:10 AM »
had a quick look to the delta manual.
for my understanding P1-00 should be : 1042
Thomas
Arman
20
Reply #6 on:
November 14, 2014, 05:56:40 AM »
let me to check it
Arman
20
Reply #7 on:
November 14, 2014, 06:03:39 AM »
It works Thomas... Thank you so much, I am breaking my brains second day...
I am building 5 axis big cnc machine, will drive it with 6 servos, and ATC spindle, if I need more help with settings I will ask your help here. Thank you again...
Carnoustie, Scotland
Reply #8 on:
November 14, 2014, 01:08:00 PM »
Would like to see some pics of that machine
Arman
20
Reply #9 on:
November 14, 2014, 01:53:02 PM »
I should post pics here?
Print
Pages:
1
2
3
4
Go Up
« previous
next »
