Hello
Guest
it is
November 13, 2026, 05:54:20 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
PoKeys
(Moderator:
NeoTO
Negative value in feed override using an encoder
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Negative value in feed override using an encoder (Read 16844 times)
progress
28
on:
November 12, 2014, 07:55:12 AM »
Hello,
I've used an encoder to change the Feed Override value and a button to reset it to 100%
But now I can set OVR to 500% and over and set it to negative values like -100%
When it goes in negative feed nothing happens because the mill is still in hold position but it's not much nice to see.
How i can tell at Pokeys plugin or at Mach3 that the minumum FOVR is 0%?
May I use a brain to do it or there is a specific setting?
Logged
fabhund
42
Re: Negative value in feed override using an encoder
Reply #1 on:
November 25, 2014, 12:28:05 PM »
+1 as I have same problem.
Did you notice that the FOVR above 300% dosen't change the actual feed ? (So above 300% nothing happens, just like below 0%)
Logged
NeoTO
504
Reply #2 on:
November 25, 2014, 02:12:05 PM »
This will be fixed in the plugin in next release.
Logged
www.poscope.com
home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
progress
28
Reply #3 on:
November 25, 2014, 02:56:52 PM »
great! I hope you will go ahead to improve the plugin for Mach3, and not only for Mach4!!
Logged
progress
28
Reply #4 on:
December 12, 2014, 04:23:46 PM »
hello,
I have upgrade the plugin and the firmware v3.1.42 , but the problem still present.
When i turn down the encoder to decrease feed override, it go down under zero in negative value.....
Logged
Print
Pages:
1
Go Up
« previous
next »
