Hello Guest it is September 05, 2026, 09:00:51 PM
Author Topic: Parameters - how to show the numeric values ??  (Read 9230 times)
« on: October 27, 2014, 06:00:42 PM »
How can I show the values of parameters which are being used by the program ??
I am working on a general purpose code to execute a series of moves (G0, G1, G2 or G3) using data from a table - but there is a problem somewhere and I need to know if the correct values are being entered into parameters from the table - but I cannot find in the manual any way to see the values as the program is running.
Any ideas most appreciated - when I have fixed it I will publish here.
Re: Parameters - how to show the numeric values ??
« Reply #1 on: October 29, 2014, 07:57:59 PM »
There is a Var monitor built into Mach3. Open it and assign whatever #var numbers you need to see. It runs in a seperate window so you can run mach3 and watch the vars at the same time.
(:-) TP
« Reply #2 on: October 30, 2014, 05:50:22 AM »
BR549 Excellent thanks - sounds like the answer to my problem - but where is it located please  ???
I have searched evrywhere I can think of but not located - nothing in manual.
Many thanks
« Reply #3 on: October 30, 2014, 09:50:57 AM »
I do not have mach3 loaded on this PC but it is in one of the pull down menus on the top of the screen. I think it is in the operator pull down menu.
